Hi Guys and girls,
I have a completely stock 97 R33 Gtst Series 2, it has 82000Km's on it. Had it on the Dyno the other week because i have had some fuel economy issue. Just though i would post up the graph and get any comments, thoughts, opinions.
Just though some of you guys might be curious.
Ps. i know there is a dyno section but i was after some comments so i though i would post it here.
Cheers,
Dan
https://www.sau.com.au/forums/topic/360948-dyno-graph/
It's quite lean for a stock ECU.
Rare to see one @ 12:1 around peak torque. I'd almost be inclined to say your fuel pump is perhaps on the way out.
Otherwise though it's not unsafe, and totally fine/to be expected in terms of result.
https://www.sau.com.au/forums/topic/360948-dyno-graph/#findComment-5762332
Thanks for the reply,
The tuner also mentioned that there was an issue with the o2 sensor as he said it was pumping in way to much fuel under certain loads (Sory cant remember where) around 30% more. The o2 sensor itself seemed to be in ok condidtion so he suspected a wiring issue or something along those lines for it to be misreading.
Other than that he seemed to be happy with it.
https://www.sau.com.au/forums/topic/360948-dyno-graph/#findComment-5762585
Yeah could be anything in the fuel system
Just get the pressure checked, filter swapped and then have a look.
Might be nothing, but 12:1 is just a tad leaner than the stock ECU normally behaves so it might not even be a problem as every car and ECU does respond a bit different
https://www.sau.com.au/forums/topic/360948-dyno-graph/#findComment-5763015
NisMoiddddddddd looks fine to me, I still had the wb O2 on my GTS-t when I returned her back to stock and noted the A/F. I played with the CAS +2/3 degrees and noticed it ran a tad leaner than usual on full load.
Economy, go replace your stock O2.
Who's the dyno operator? O2 is only for cruise when the plenum is -ve pressure. On load, O2 does nothing.
https://www.sau.com.au/forums/topic/360948-dyno-graph/#findComment-5763127
Ye it looks fine to me too dude. I never said it was bad.
Just a little leaner @ 4500-4800 than you'd expect. But by no means is it unsafe how it currently is and would be fine to use. Its perhaps just a sigh something might be needing attention. That is all.
https://www.sau.com.au/forums/topic/360948-dyno-graph/#findComment-5763179
Thanks for the feed back guys, dyno was done at unigroup.
First import, still learning about all of these things. didnt add this before but he seemed to think that the ecu was reading the o2 sensor wrong, it was pumping in fuel even though it was getting plenty. I know i keep brining o2 sensor up but he said it will more than likely be the issue behind the economy issues (i am struggleing to get to 300 city driving and even cruising on the highway i am bearly making 400km to a tank, that was on a good week).
I will also have a chat to him about the fuel pump now that you have bought it up, and i assume you say that purely bassed on it not pumping enough fuel through the system, hence running lean.
Apologies for lack of understanding but im still learning learn.
Regards,
Dan
https://www.sau.com.au/forums/topic/360948-dyno-graph/#findComment-5763358
The main thing is, it goes lean [but not engine destroying lean, just leaner than you want it to be] when you increase the revs. It is not lean until you get up in the range. This means that it passes enough fuel for down low but leans off up high = a lazy pump or a clogged filter.
https://www.sau.com.au/forums/topic/360948-dyno-graph/#findComment-5764866
Id agree with that. Its better to be safe than sorrry.. bad batch of fuel or a stupidly hot day perhaps? Is that that area of the stock ECU where it pulls a bit of timing too?
https://www.sau.com.au/forums/topic/360948-dyno-graph/#findComment-5765420
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
