I just fitted a V-manage unit with the help of my tuner Cihan, it doesn't seem to be outputting the correct signal to the cam retarders but I can read the stock cam mapping quite well. It seems to be advancing the cams early on, before the stock turbo makes boost which is promising, up to 30 degrees advance from what I logged.
The VQ35de data I am using to control it must have a different signal to run its hydraulic cam retarders, and there doesn't seem to be any other CVCT VQ's listed. Does anyone know of a different VQ that runs the same electromagnetic actuator?
Not looking good for the cable throttle install as the cams will go into full retard once the engine is in limp mode, unless I can get this working.
I have emailed Greddy Japan for support but im not holding my breath...
https://www.sau.com.au/forums/topic/361418-m35-v-manage-install/
  • Replies 104
Posted Images
Hmmm maybe its time to save up for a GZONE remap....and a complete retune :whistling:
yup....do it!!!....be a pioneer!
might find some others follow once they know it's good!
Edited by Jetwreck
Not 100% certain but as stated last night the VQ23de will probably have it.
Actually.... it references the CVTC only for VQ25det and VQ23de on the VQ section of Wikipedia
Hmm... the VQ23de was used in the Teana in the US, so maybe you should talk to Greddy US instead of Japan.
I'm actually in the process of doing this at the moment.
After I saw that listing on Import Monster, I spoke to a colleague who knows Japanese, and she passed the information on to a friend in Japan to be the go between person.
At the moment it sounds like it'll be about $600-700 if I supply an ECU, including removing the speed limiter and throttle restriction. They'd prefer to have the whole car, but obviously that's not possible.
I'll keep everyone posted, but I might want to borrow that ECU sooner rather than later Craig :thanks:
Good stuff. I would definitely be interested in a remap especially if we can get better economy as well as the removal of the throttle restrictions down low.
Hate to break it to you mate, you'll never get better economy when you have a more responsive throttle and more power!
unless you want spend 5k and get LPG installed :whistling:
Is that working under the assumption that with a more responsive throttle and more power you'll be more inclined to put your foot down?
What's the throttle controlled by!
Edited by Jetwreck
Definitely keep us informed of how this progresses, I dare say there's enough demand to justify your effort!
There's enough demand right here to justify the effort :nyaanyaa:
I'd say it'll be easier with a Japanese translator, just have to work out cost and procedure, then maybe we can organise to send a few over, assuming the first one goes ok?
Happy to be the guinea rat, sounds like it'll be worthwhile regardless of what aftermarket stuff I run later.
I have a spare ecu also if it all works out. :)
You will still need some way of adjusting fuel and timing though if you have gone the highflow path... No way you can guess that tune from the other side of the world.
Just rip out all the VCT and put some big f#$k off solid lift cam's in.....the idle would be awesome!!!!!!.....lol!
I had the lumpy idle yesterday. lol. The engine wanted to stall with the actuators on full advance.
Good thing I found that Emanage CD last nite!
Well I'm guessing that part of the tuning may well be a leaning off of the A/F ratios which will most certainly give better economy. Not everyone drives like a wanker and has to fang it non stop. Better off boost and low boost around town economy should be easily achieved by this. I can accept poor economy if I cane it but when I drive on the highway or around town with the kids in the car I would like better economy than I'm getting now.
Might be clutching at straws, but the VQ35HR motor had hydraulic intake and electromagnetic exhaust. that help at all?
complex answer on a VQ25det!!! :wacko:
The HR isnt supported by Greddy, why I have no idea, its only programming the pwm outputs as far as I know. Cant find an english manual anywhere either. Not the smartest considering half their gear is bought by overseas customers these days.
I wish there was better support for this as its a great product with many uses, these variable cam engines are just starting to be unleashed.
I haven't gone down that path yet, but I will. I figured when I got to that point I'd need an Emanage or something similar regardless of whether I get the G-Zone done.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
