Hey all,
Wakefield Park doesnt need much of an introduction to most of you, to anyone thats never heard of Wakefield Park this is a very safe track about 2 hours from Sydney where you can drive your pride and joy as fast as you like with safe run off areas and no speed cameras to worry about!
This day is being run in conjunction with the Rotary club (RENEW) who we did trackdays with quite a long time ago aswel as recently in March, RENEW have 24 spaces and we have 24 spaces.
If you've never driven on a track before and want someone experienced to give you instruction and help with how to drive better, faster or safer, or even if you've done a couple of trackdays and just want to ask some questions (no matter how silly they may seem) we have this at no extra charge available throughout the day.
For the trackday regulars we have a friendly interclub challenge between us and the RENEW club. THIS IS NOT COMPULSORY!
Ok so here's the details;
Date: 28th May 2011
Where: Wakefield Park (www.wakefieldpark.com.au for directions)
Who: Anyone with any car (doesnt have to be a Skyline)
What: Trackday, suits total beginner to advanced
What time should I get there: 8am at Scruitineering for experienced, 730am for beginners (Scruit finishes at 840am sharp, if you're late you need to wait until the day has started so the rest of the group isnt held up)
How much: SAUNSW and RENEW members $210 per driver, non members of those clubs $250 per driver
Lap timing: Included
Passengers: Allowed, must wear helmet and same clothing as drivers aswel as sign an indemnity form and pay a small fee
Licence needed: CAMS L2S or AASA club licence ($50 for 12 months, yes you can arrange this on the day no worries)
How the day runs;
Firstly, when you arrive at the track, find a place to park and empty all loose objects out of the car. Ensure there's nothing loose in the engine bay and no leaks (More info on scruitineering will be posted up at a later time). Then drive your car to the scruitineering shed (its marked, but if you dont know where it is, follow where everyone else goes or just ask someone, its very easy to find, directly on the left as you enter from the highway). Your car will be checked to make sure its safe to go on the track and it will then be assigned a number which is your number for the day. You then park the car back in your original spot and go to the office to sign on. Take your licence with you or if you dont have one, this is where you can get one. Once you've signed on its now time to wait for the drivers brief to begin (which will be announced on the loud speakers throughout the pits and starts at 845am sharp). Once the drivers brief is over, all the drivers are split into groups based on experience so that everyone is comfortable in their group. One group is then allowed on the track at one time for evenly timed sessions, once one group comes off, another goes on, this repeats until the end of the day with a short break around lunch so officials and helpers can get some food and drinks.
Differences for this day;
-Fire extinguishers are mandatory, must have the Australian Standards sticker, be full, mounted securly and somewhere in the cabin
-Metal valve caps on all wheels, dont stress over this, they will be supplied and fitted at scruitineering
Thats basically it! The only way to secure a spot is through sending in an entry form and payment to the RENEW account. The very basic entry form is attached to this post and the bank details are below;
RENEW bank details:
Bank - CBA
Account name - Rotary Enthusiasts of NSW
BSB - 062 272
Account number - 10106600
Please put your LAST NAME in the description, eg "SMITH"
See you at the track :D
-Steve
SAUNSW President
Entry Form SAUNSW + RENEW Wakefield 28th May 2011.pdf
Supp regs SAUNSW + RENEW Wakefield 28th May 2011.pdf
  • Replies 204
Entrants List:
1. Michael Hill
2. John Sykes
3. Andrew Trieu
4. Mark Robinson
5. Brian Bugh
6. Nathan Dean
7. Mike Bennett
8. Scott Bunny
9. James Westhorp
10. Ben Martin
11. Trent Kennedy
12. John Penlington
13. Ben Kerker
14. Anthony McAlpine
15. Ron Lea
16. Greg Boyle
17. Nick Barker
18. Reece McIntosh
19. Andrew Middlebrook
20. Daniel Haysom
21. Josiah Haysom
22.
23.
24.
RESERVE
1.
2.
3.
4.
5.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
