The problem with just changing the resistance...
You still have a 15yo AFM that's most than likely going to fail at some point given just about all of them do.
But new ones and you'll never have to worry about it for another 10-15yrs. AFM issues can often being a major pain in the ass.
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5779385
I got mine done by the same people mate, havent installed them or run them yet so comment on how well they work
the way i saw it was
1. I can either go to the trouble to sell my standard ones, buy second hand z32 ones, screw around with plugs etc
2. Buy genuine nismo ones that are more then $1000 dollars as a pair from memory
Or 3 get them cleaned recalibrated and have them still looking stock and able to bolt straight back up to my apexi intake system... remember though ull need to pay for postage to send your standard ones off and get them sent back
cheers
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5779694
Closer to $750 exchange rate depending
Sell old AFM's for $150 - ~$600 for brand new, high resolution AFM.
Not a bad deal if you ask me. Especially if one of your recalibrated old AFM dies... You are immediately behind in both cost and downtime for the car as you now can't use a stocker AFM to get you out of trouble
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5779761
agree with r31nismoid
airflow meters can fail with age and are crucial for engine management operation
i see no reason to skimp on them when you can buy brand spanker new nismo's off the shelf readily avaiable guaranteed
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5792983
Haha well that's not very comforting! Lol. May have to look into genuine nismo meters then because these re-callibrated ones are $275 or $295 each (exchange for old ones) so like you said if you can pick up a pair of genuine nismos for around $750, sell old ones for $200 you're paying the same for brand new genuine really
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5792993
Go for the NEW Nismo AFM's, i was trying to put off getting them because of the cost.
But really, you have to see the benefits
1 - they fit up as stock (air box, apexi pods, etc)
2 - they're new, so they should last a good 10-15years at least
3 - they allow so much more flow to be reliably measured
My missus WRX had the engine go in it, and it was because it was running stupidly lean because the AFM wasn't reading properly and leaned the mixtures out. it cost her $7,500 for the engine and she still had to get a new AFM. the AFM was a $250 part and because it was stuffed it caused over $7k damage.
the question i asked myself is, do i really want to skimp and save a couple hundred dollars and still effectively run a 20 year old AFM or go for a brand newie and not risk having any major issues caused by the AFM's
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5793549
Would go for ecu with map sensors but want to retain factory airbox etc and only looking to achieve around 300kw atw. Probably cheaper to go something like d-jetro and not worry about afm's but Unfortunatly cops up this way don't take kindly to pods or made up airbox"s etc and an R34 gtr kinda stands out on country roads lol.
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5793761
You just get drama of a different kind to replace it with.
Nothing isn't without drama.
Like what?
Mine's been on map sensor based ecu's since 2 weeks after I bought it in 2005 and havnt had a problem with map sensors.
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5793789
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
