Is your 44k yen price inclusive of the throttle restriction removal and speed cut?
According to their listing on YAJ the list price is 44k. BIN @ 46k
http://www.importmon...RO%20SPEC%20ROM
Note this on their listing:
It starts coming out at setting, and the entire area an empty torque impression there is, setting, very much is popular. The map of the NM35 electronic control throttle short story low/row which only NISUMO understands until now, with) modification such as variable val tie & electromotive fan start timing (temperature analytical real accelerator work in furthermore high power higher rotary limits was actualized until now. (Note!! Successful bid charge + separate option cost)
I think Cam found out it was a 20k yen option to remove the throttle restriction...
If your contact can get the remapped ECU WITH the restrictions removed for 44k yen then I'm impressed...
Edited by ironpaw
That was for simply_mighty, who wanted the tune minus the throttle restriction and speed cut.
You're right, its 20,000 yen to remove those. I'd like to think we can get this reduced if we're getting a few, and I haven't had a chance to ask if they can just do throttle restriction and speed cut.
Dude you don't need emanage if your just changing the exhaust, you only need it if you want to install the suction pipe and increase injectors size. Even then you don't HAVE to get an emanage. Cam isn't running one and his car's got all the mods done cept for injectors...I think.
Well that solves that then. It is on my list anyway. I've never had anything this 'high tech', so I'm just kind of feeling my way and erring on the side of caution. Doesn't help when you read/hear/get told different things and you're trying to work out what the best move is! All very confusing sometimes... I have bought myself more time now anyway, so might do the G-Zone anyway.
Yep, suction pipe, turbo, FMIC, spacer, full turbo back exhaust... and stock ECU.
It won't pull as much power from the car as a dyno tune with piggyback will, but you certainly will not NEED to install the emanage if changing the exhaust.
Love it. Thanks Cam. Bad info had made me think it was necessary and I was going to lean out and break stuff.
Are you keen on the G-Zone then? Or you looking at Emanage? Both?
I think I might do it when the car gets back.
Do we have enough ECUs floating around to send 4-5 over to get done at the same time? He might drop the price if he just has to remove speed cut and throttle restriction from 4-5 ECUs? These are all things I'll bring up with him when my Japanese contact gets back online, apparently its a holiday over there at the moment but Mr Amino keeps working away at G-Zone.
Dust hasn't done his write up yet, what's the advantage of the Fcon over the Emanage? Don't they both work as piggybacks and didn't I see you post that neither controlled the eVCT?
lol, my decision had nothing to do with Dust and his brief description of the change.
the Fcon iS is a piggyback - takes the ECU's signal to the engine and manipulates it (like the eManage)
The Fcon V Pro is installed like a piggyback but can be used as a standalone unit - cuts off the ECU's signal to the engine and sends its own.
Controlling the "eVCT" is an unknown to me right now.
The iS can control NVCS (Nissan Variable Cam Timing) which was used in the RB25's but I am not 100% sure about controlling the timing in a VQ25det... yet.
Edited by iamhe77
I asked to G-ZONE over e-mail and he replay this email.
デンスロは、別途オプションですが、ノーマルデーターが沢山あるため、オプションにも対応できていません。
解析が必要なのです。G-ZONEのステージアのコンピューターが評価が高いですが、デンスロをいじった車はありません。
出だしが遅いステージアに関しては、吸排気系のバランスが取れてないか、(燃料、点火時期)だと思われます。
ステージアは、酷く燃料が中回転だけ、濃く後は、ノーマルでも薄い状況です。
stagea has too many ecu number (I think 12)so electric throttle is option but we can not change throttle map.
Many stagea have been installed on our remap ecu and are very happy but we have not been selling remapped throttle map ecu.
We think your stagea problem is fuel or timing map problem.
Stagea is very rich at middle rpm and after middle rpm is lean.
Also TEPS is able to change throttle map but have not been soling remapped throttle map ecu.(customer is happy)
I know ecu specialist and I spoke to him and he is able to make map for 98 octane fuel.
If you are not happy he will adjust map again.
Its free but you need pay postage.
He will change fuel , timing , also throttle map , remove limiter.
Price 60000yen all included.
Cheaper than G-ZONE.
Thanks Toshi, very helpful. I take it you are not going to buy the reader/writer yourself? I think at around $500 for a remap the reader will pay for itself very quickly as I think there is at least 10 people wanting this done.
Tools around $7000.
$500 for US nissan car.
Japanese car can not use it.
Also $500 one can not map trace and datalog.
M35 is I think around 12 type ecu and all different program.
So If I do my self I need map tracer and data logger.
ECU tuner said if this ecu will engine knock , too rich , too lean , I will remap again.(its free but need postage)
So I think this is best way now.
Sounds like this might work; Toshi, would you be able to arrange a run up on a dyno to observe how the remapped ECU behaves, and then provide feedback to the tuner regarding any issues if any arise as part of the process?
If so, I'd volunteer, if someone is prepared to loan/rent me an ECU? Otherwise, who's willing to go first?
You have an informeter don't you Daleo? I just want to know if they can fix... Actually dont bother. lol.
Sounds positive :)
Lom changes
Speed ​​limiter changes
Fuel Data Map Change
Valve timing control map change
Ignition map changes
Throttle control map change
Professional expertise Romuchuna injection
The acceleration torque from launch.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
