Where I am Premium Bp unleaded fuel cost $1-80 with the other unleaded fuels $1-60 and the lowest octane at $1-50.
I am advised to run only the highest octane rating eg Bp Premium unleaded which I always do.
However my next trip will take me into areas where they dont have the premium brand.
Not sure how long I may be doing this either.
What advice can you give re running on a differetn fuel?
What possible damage may result?
What sort of mixture can I get away with, if any at all?
My skyline can run both but this car cant according to the specs. Why is that?
https://www.sau.com.au/forums/topic/362590-fuel-do-i-have-a-real-choice/
I've heard of some guys running lower octane fuel when the other wasn't available and not had any problems.
If you car is fairly standard you could probably get away with it, especially if you drive it conservatively whilst using the lower spec fuel. Otherwise you could carry some bottles of octane booster and add those. However, I haven't had any experience with this so don't know how good they are or if any brand is better than another.
I had a skyline once that was perfectly happy on regular until I changed the exhaust. Then it just ran rough & farted & carried on unless on premium.
The VQ25DET engine is a highly specced engine, much more so than a tractor.
NF Octane Booster works well, the Black one. I used to sell this, and used it. Worked well. Also works well if you've got a leaded car, lets you run unleaded.
Where are you going? I thought I might struggle getting 98 on my drive home but everyone had it!
I was recently in country NSW and couldn't get the BP Ultimate 98 Ron (what i normally run on) or any other brand 98 Ron fuel
So had to go the standard Premium 95 Ron for couple of tanks
Didn't have any issues on it other than i could feel a bit of loss in my accelation power
and my engine didn't have as much of the throaty growl from the air intake on acceleration (Air filter inspection cover removed)
Even with the very limited Fuel staions there was still the option for the Standard Premium 95
if i didn't have that option would have definately been using the octance booster
95 won't hurt your engine. Sometimes forced to run 95 with only minor reduction in economy if any thing. You won't notice power difference cruising on th highway imo.
While I haven't tried it have been told the ECU will also cope with 91 if stuck. You shouldn't find many places that don't atleast have 95. A lot of country Caltex have the 95 but no 98. Shell seem to have the 98 in country stations though not my fav fuel. (NSW)
Wouldn't waste money on octane booster - if you are thinking of using these, research the actual boost to octane you get for the $ - stuff all. That might change your mind.
in my c34 i run that ethanol mix crap, that so called e10 91+, car works fine, only get about 370-400km on a tank but then again i drive pretty heavy. i have run 95, 98 and once 100 octane, all feels the same crap, on e10 no problems of missfiring, no smoke, no running rough, all works perfectly. if i run unleaded 91 no ethanol, it feels a bit choppy to drive though.
Isn't 91 octane with 10% ethanol actually that 94 rated stuff?
I've almost always found a difference with fuels.
Caltex/Woolworths stuff none of my cars have been as happy on, and I've always found inferior fuel economy.
Shell I hardly use, however I did find on the drive from Sydney to Adelaide the tank of Shell 98 didn't give me as good economy as the BP 98.
BP Ultimate has been the best fuel I've used on previous cars, better economy and generally better behaviour from the cars.
The E10 blends have also been pretty good, and I've been very happy with the 100 octane E10 I've been using. Car feels snappier, economy I think is pretty good for how I drive it.
As for octane boost, it definitely works, but whether you need it or not is another matter. Get the right stuff and it works great as a lead additive/substitute if you've got an older car. Whether you need it or not is another question. Ben at Northshore told me to run mine on 98 when I bought it, but said push come to shove you could run it on 95 if you had to, but it wasn't recommended.
What I can't work out is why they'd bother stocking 95 in rural locations? Wouldn't they be better off with 98?
Maybe I am missing something, but why bother using 95 instead of 98?
Our cars definitely run better on the higher octane, so the only thing I can think of is the 4c saving between the two.
Why not just get Shell V-Power and hand over a Coles fuel docket to save the 4c per Litre (works out to be under $3 saving per tank lol)
99% of my fuel is V-Power as it is the most convenient stop for me, but Mobil 98 and BP 98 are both good too.
Haven't noticed any real difference with economy between the three (I used to use BP and Mobil all the time).
Vortex 98 on the other hand... :glare:
Once I did the numbers on Km travelled per tank of fuel, V's price; I stopped using 95. The extra distance per litre negated the price difference.
I don't get that either Cam. I know we have the fuel cycle etc, but really it usually equals less than $5 swing. I can't be bothered.
I've not used Mobil 98 because there are no nearby servos, and I only use Shell on trips if I have to, just because there are no servos near home. I usually just use what I know. I'm sure Shell is as good as BP Ultimate, I just don't use it for convenience. That and I'm loving the 100 octane :D
In Adelaide, United to a 94 octane E10 and a 100 octane E10.
My understanding is the 94 octane is 91 octane unleaded + 10% ethanol, and the 100 octane is 95 or 98 octane unleaded + E10.
Been around for about a year now. I used to run my BMW on their 98 octane E10 and it loved it, now that they've got the 100 out I use that.
I've actually seen dyno sheets from saloon cars being tuned on Elf and the 98 E10, and they found that the 98 E10 gave them only 1 or 2 less kW over the $5+/L Elf, except that the 98 E10 was only about $1.20/L back then. Something about the ethanol content.
Going Darwin to Brisbane.Last trip several places had run out.
Big kev wrote
"Sydney to Adelaide the tank of Shell 98 didn't give me as good economy as the BP 98".
What litres per Km or km per 100km did you get with BP /shell?
Edited by samuri
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
