SO i am stripping my 33 Gtst with a built 26/30 down for racing and am considering converting from a single GT3582r with a 1.06 housing to twins.
What twins to drop in is the million dollar question. Previously had good fun with a 3076r - is there a chance to do two of these. Aiming for good boost response say upwards of 3000 rpm. Currently have 310 KW so around this mark will be perfect.
Thanks in advance
Mike
https://www.sau.com.au/forums/topic/363127-twin-turbo-reccomendations/
Save your dollar and change the turbo to suit your application, the 35R with 1.06 housing is more like your aiming for 400rwkw. You could simply swap out your rear housing to a .82 item and shoot for 350rwkw, response will be great and power will be thick and plentiful.
If your aim is honestly 300rwkw, the above mentioned 3076 with .82 rear will be an all out animal. I would recommend this over the said twins (-9s), not to undercut the stripey horse but redeveloping your entire setup to achieve 300rwkw is not necessary.
Consider the twins will cost you over 2k to buy, plus redoing your exhaust and intercooler, obtaining all the factory piping etc etc etc and making your car THAT much harder to work on.
You could buy a 3076R that uses the same rear housing arrangements and dimensions as the 35R, it will also have the same 4" intake and your intake pipes will even easily accomodate the change. The 3076 would set you back a maximum of something like $1800 from GCG and you would have near the ultimate 300rwkw turbo for a 3L motor.
Youtube amuse supra, its got a 3076R on it and has BULLSHIT levels of power/response.
You are absolutley correct - when i built the motor , I was originally planning for 400RWKW plus - but we hit the limit of the fuel system - and without moving to a surge tank and additional pumps, I was stuck at 310 - hence the original turbo choice.
This year I have decided that my new project will be to race the car, and as such she is being stripped ready for a full cage and re-spray. I always knew that he current set-up would not be optimal and hence the question.
Cost whilst a consideration is not prohibitive, and i have no requirement for factory piping, unless it fits, as I have no need to remain RTA legal.
Back when she was an RB25 - the 3076 was a great piece of gear - but will it still stand now its 26/30 and is going to be raced. I reckon given teh cage, sprayjob, new wheels and tires, big brake upgrade, new ECU, electronic dash and all of teh other goodies - I am unlikely to see much change out of $30-35K. The engine is already built, so only the head will need work, besides a strip down and check/balance.
So the question still stands - single or twins, which will be thebest for a 970 - 1000kg RWD track car????
I am running 383 kw at the rear treads (dyno'd in RWD so as not to detonate front diff) with twin HKS 2530's on an rb26/30 setup. Still running (ported) OEM cast iron manifolds. Very responsive.
With tubular manifolds (expremes or similar) i reckon could be even more responsive.
What boost?
What other mods?
http://www.skylinesaustralia.com/forums/topic/275548-andrews-r32-gtr-bolt-on-build-thread-phase-i-of-my-mods/page__st__60
22psi. Anyhow, the main point is, the turbos are now the major bottleneck in the system, but the HKS2530's are capable of making that kind of power on a 3.0, even with stock cast iron manis.
2530's are bigger than -5s right.
So - if most people get 380rwkw on 20psi with -5s on 2.6ltr... running more boost, on bigger turbos, bigger motor... I think you've got issues somewhere.
You should be well over the 400rwkw marker.
no, 2530s and -5s are basically the same. few small differences in the HKS ones but nothing major. 350kw @20-22psi is more like the norm for a good set-up so 380rwkw on a 3.0L is about right. it's a good result.
most people get 380rwkw on -5's at 20psi? bit high wouldn't you say? - i had a dig through the rb26 dyno thread for 2530 results and from what i could tell, around the low 20 psi mark, 21,22,23 people were making 350-360aw/rwkw - which i thought was about spot on for the 2530's?
on 3 different dynos i've had 358, 353 and 357 around 21psi
High how? Look @ people like Aaron34, Tangomatt etc making 400-415rwkw with 2.8ltr's on 20-22psi with -5s
Im @ 365rwkw on 19psi with timing pulled out. Jack & Snowy both made 370-380 (-5, 2.6ltr). I've posted the graphs up before.
Don't forget we aren't talking stock motor results. They do indeed sit around the 350rwkw marker on stock motors (hence i think -5s are a bad choice) - so no argument there from me at all, totally agree.
Built motors with some porting and so on make more in almost every case.
-9s and GT-SS are identical - 2530 and -5 are not.
2530s are bigger, and will make more power. A 3ltr, running more boost again (when you factor things in), evidence would suggest it should be higher.
Could be exhaust restrictions, or perhaps just a conservative tune or something else entirely.
It'll be good to see when Paul & Steve get their -5s tuned on 3ltr and 2.8ltr respectively. That'll hopefully provide some more results.
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
