i have a full set of gtst bilsteins. the fronts will fit gtr. happy to sell just the pair with springs out of a gtr.
Are they height adjustable with threaded nuts? or just standard type struts? i need height adjustable ones :)
that would be spot on mate, cheers
Ive got one you can have for free mate if you can pull it out but it has paint all over it, could be cleaned off i would imagine... you could just cut the bodyshell up and take the whole rear pillars and get the glass removed somewhere else also.
cheers mate I'll keep that in mind, see what I come up with.
i know of one out of a stag 34 same thing :) its on Lton could get it cheep under 50 :) ill msg the guy if you want
I want to replace the one out of my stag, the stagea ones are terrible, half half the size of R34 GTT SMIC, cheers though.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
