Hi guys,
My partner just blew the turbo while I was driving right next to her. No boost and a horrible (Awesome?) squealing sound.
Now I've heard of people getting a hypergear highflow/rebuild, as well as GCG.
I'm basically looking for cost effectiveness, happy with a slightly above standard rebuild but no more and not chasing power either. Who/what have people gone with and what are the recommendations?
Based in Canberra, if that helps. And if anyone has a spare they want to sell, I'll take it!
P.S - I did search but kept getting timeout errors
Cheers,
Sean
https://www.sau.com.au/forums/topic/366367-so-my-turbo-just-blew/
  • Replies 165
one simple answer, gcg = ball bearing highflow, hypergear = bush bearing highflow. i realize your have a v6 and i have an rb25 but i just had the same thing happen and from all the stuff i looked at hypergear is your most cost effective answer. he will make you a turbo to suit your needs.
I can't help you with that one sorry. I'm sure the M35 guys will spy this thread soon enough and give you all the info you need. If your keen you could check out the M35 forum some of the guys on here setup, might find some info over there, from memory it's m35stagea.info
We had Hypergear high flow an M35 turbo to close to stock specs (ended up being a sort of "2861" core).
It was a bush bearing job and the owner was very happy with the end result and the price was quite good.
Send GlennM35 a PM, is in Canberra too and may still have his car (haven't heard from him in a while)
The GCG high flow is massively laggy and definitely not for someone who wants a stock type of rebuild.
Cheers Josh :thumbsup:
Andy - What was the costing on your turbo?
Jetwreck - PM'd
Sean
As was mentioned above. $1350.
This turbo is slightly laggier than stock but has strong mid range and comes on very strong from 3000rpm. Positive boost starts to build from about 2200rpm.
Cheers
Andy
Hey guys,
Got a few quotes for anyone interested in the future -
GCG $1380 excl shipping
Hypergear $990 incl shipping (slightly larger proficle, bush bearing core)
My mechanic can't fit me in and the next best quote for turbo replacement is $2500.00 labour!!
So needless to say, I'll be attempting the work myself over a number of days (engine in) if anyone has a few tips to help me out, or some specialty tools they found useful.
Any tips? Turbo still in car, ready to be removed when I have time though
Cheers,
Sean
Aaron should be able to help...he got it out in 2 hours! That's with the engine in!
Time for a "how to" guide Aaron? Certainly not a job I'm looking forward to.pinch.gif
Or is that due to your lack of factory heat shields?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
