Nah its a 1993/4 with sedan headlights.
Other than that, looks clean.
edit: see a WA number plate? Head over there and introduce..
meaning it's probably been in a crash and had new headlights put in.
could still be a 95 model and someone changed the boot to a s1 boot (don't know why, but some people do do it)
best bet is to post the vin the in FAST section and/or post pics of the engine bay and interior. that will give some indication as to what series it is.
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5846648
Doubt it'll be 95, 95 should have the series 1.5 front bar (unique bar). Unless, as you say, it's been in an accident and they replaced with a series 1 bar.
What are you doing in here Marc? Obviously the same thing as me.
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5846824
pretty much
but yeah, my 95 33 had sedan headlights and the crappy sedan front bar. i never go off the front bar as they are so often changed. i've never been totally confident about how people say that the more agressive front bar is the series 1.5 because of the amount of series 1's i've seen with them. i think it is more to do with whether it is a sedan or a coupe. same goes with the grill.
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5846882
Because GTS R33's have RB20's, GTS25's have RB25's. I don't believe the RB20 models are allowed for compliance but when I was looking for mine I saw a 4 door with an RB20E registered in Queensland so I thought I'd ask.
Edited by miguelegant
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5847092
Pretty sure 99% of people call them GTS or GTST's. I don't think I have ever called mine a GTS25T or have heard any one call theirs that.
And no they are not allowed for compliance with a RB20 but there are some in Aus.
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5848247
yep, there's one in gympie. is an auto with a GTR bodykit, LOL
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5848363
haha i remember seing it for sale i think, what a joke that car must be.
Probs gets overtaken by Prius Hybrids, lol
the one in gympie is maroon, still has the GTR endplates on the rear wing and the GTR badge in the grill and a gts-R badge (that looks like a GTR badge from a distance) on the boot
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5848497
ahah okay, well ill try answer as many questions as i can..
1st. yes i think it has been in a crash..
2nd. it was cheap
3rd. its my first car
4th. im only on P plates and i didnt want to start out with a powerful car that i cant handle..
(: all in all im happy with it for $5000 i thought it was a good buy and in the future ill either get a turbo or convert to turbo
sorry about the bad image.. ive put a pod filter on since..
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5851607
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
