Hey everyone,
Recently purchased an R33 GTS-T, stock clean and generally beautiful, except one thing. The previous owner installed a screamer on the turbo, bottom line is I hate it, im not about the attention and its just a bit shit really. What am I looking at to get it removed, whats the proceedure and who would I see?? Sorry to be all newbie and shit but im new to turbos and thought you might give me some insight.
Anyway cheers
https://www.sau.com.au/forums/topic/366603-stupid-screamer/
A import exhaust center can remove it (or any exhaust center that know a thing about turbo's lol) would have to fit a factory dump pipe or aftermarket which is better and less restrictive then stock obviously to replace the screamer though
Edited by nismo07
https://www.sau.com.au/forums/topic/366603-stupid-screamer/#findComment-5848208
any exhaust shop would be able to fix it
unless
he has hacked apart the exhaust housing on the std turbo to fit a dump external pipe
if he/she has done that just buy another std turbo for $100 from someone selling one
https://www.sau.com.au/forums/topic/366603-stupid-screamer/#findComment-5848214
Get a photo for accurate advice, then we can recommend the parts needed to change it and where best to buy them.
Hopefully its just a silly split dump pipe and a simple justjap belmouth dump for 200 bucks will fix it for you, and all round better performance too.
https://www.sau.com.au/forums/topic/366603-stupid-screamer/#findComment-5848530
hard to get into take a decent photo for you, but it appears to be a JJR Stainless screamer dump pipe.
http://justjap.com/store/product.php?productid=16996&cat=&page=1
Is it as simple as it seems to purchase a JJR Split dump pipe and bolt on?
http://justjap.com/store/product.php?productid=17009&cat=&page=1
Looks like it could be the shot.
https://www.sau.com.au/forums/topic/366603-stupid-screamer/#findComment-5851535
http://justjap.com/s...996&cat=&page=1
http://justjap.com/s...009&cat=&page=1
Very simple, a few bolts, a case of beer, a bleeding hand and swearing.
Don't get the split, just a bellmouth will do.
https://www.sau.com.au/forums/topic/366603-stupid-screamer/#findComment-5851828
Yeah for 10x the price and probably made with Chinese tube anyway
Lol. Hardly.
Andrews work does cost a bit more, but quality costs money. ;)
As for Chinese tube... +1 to Simon. Clueless.
https://www.sau.com.au/forums/topic/366603-stupid-screamer/#findComment-5852653
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
