taken off another forum
User 1 - Caltex are only and have only produced 70% Ethanol content fuel.
Its consistant 70% all year around at three local servo's here.
User 2 - He's telling me he emailed them today and they are switching to a summer blend 85% on november 30
He has gone with the decision to tune for united and then run caltex if needed.
sits tight and waits for confirmation :D
i was running Eflex at the beginning of all this, and despite a batch or two or low to mid 60's, after that, my sensor only ever read E70,bang on every time. Even in summer. We know that Caltex up until this point has never switched to a summer blend.
Then united came back in the game (big time here in Melb) and they've been very consistent, i've never seen lower then 82 or higher than 85.
I'm more than happy to run a tank of Eflex after Nov 30th to confirm this for you :)
cool cheers might make it like a week after to make sure their tanks have been over 90% refilled with a new blend
i found a quote from Martin Donnon saying Caltex had capped their E85 @ 70% for the first 2 years maybe theyre at the end of that 2 years
i will go look for quote
Q: Whats better United E85 or Caltex E-Flex?
A: That depends on the application. The major difference is that United tends to test at around 85% - 88% Ethanol content while Caltex have frozen their E-Flex at 70% Ethanol for the first two years of production. This means that although there is around a 2% greater power potential with United, the Caltex is better in 'fuel system limited' applications where the injectors and or pump are becoming marginal
Source
to me (and i've just realised this.... hahahaha) it's like having Lindt's 70% dark chocolate compared to Greens organic single origin 85% dark chocolate... you can't go back, 70% is too sweet - you need the hard stuff from then on :D
maybe my subconscious has been directing me to choose the 85% dark chocolate lol :D haha, can't believe i haven't made this connection before!
seriously though, Greens 85% is the absolute shizzle.... just like United's E85 :D
but bring on the Caltex E85! It feels like a cop out using it at the moment, more 'true' E85 outlets the better!!
I will just stick to united 85 for now. Amazing how the powerfc is so robust still with an e85 tune still.
My car is still using the nismo intank fuel pump. Not far off from reaching the 400kw mark on basic mods. The id1000s are only maxing out between 73-78% duty. So definitely impressed it with.
Go to Trent at Chequered for any sort of tune :)
Great write up Daniel.
I have a sensor ready to install in my boat, I was just wondering why you tee'd off your fuel return line and didn't run all the return fuel through the sensor?
Is the sensor restrictive?
I have twin 044's and was hoping to run the return through the sensor...
It's too small. Tee it off
It's only in the return line, it won't affect the maximum flow as the injectors are before it.
If you look inside your reg you will probably find a 2-3mm hole for the return bypass. It won't be an issue imo. I would still 'T' it off though just to be sure.
weird how Syd seems to vary more, and seems to be more on the high side? my united has been bang on E85 last few times, and before that it generally was 82-83 - but it's still been a very tight range.
uhh yeah. restriction in the return so will bump up fuel pressure if anything, brain fade!
its fine running it full return on a few 400 +rwkw cars now.
Wouldn't it depend on what the fuel system setup is? IE having 2 x 044's at full noise at idle (if they ain't setup in a staggered setup).
So you don't have any weird fuel pressure related issues at really low load with a big (300+lph worth) where the FPR would be dumping fuel back to the return?
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
