Yep, I figure there is no point getting another engine for it to just lift the head again. This way with the L19's I know the head studs are good for 1500hp or more.
It looks like VQ25's have the same head bolts as the VQ3.5de hence the same head lift issues at around 500whp. Anyone pushing for over 300kw would have to consider these L19's at some point.
This is your new target; kgo. :whistling:
Its easy, twin gt40's sticking out the bonnet should get me there. lol.
Thanks Dale but im more than happy with the powah it has now, It looks like I will have to do open heart surgery on my poor engine though, and Gleeson's.
my point exactly! i didnt know of any other ways to tell you its a waste of time and money to be fishing for a new engine with no history of it.
What can you do, no-one could have predicted I would stretch head bolts. Looks like the little 25 is not as tough as I thought. Hopefully its just the studs though.
Anyway, we can rebuild it, we have the technology... lol.
Lol, only joking...
It'll be interesting to have a proper look with the heads off, to see how bores, piston crowns & heads look after the number of km's you've done at your elevared power level.
Just how tough did you think it was?
It did overheat prior to this problem due to a radiator issue and has been pushing over 300awkw for a while now.
Not bad for an unopened 2.5.
Agreed, but if the head studs are all that need changing (and that's understandable at probably 600 flywheel hp) then lets do it and get on with tuning. Its not expensive in the scheme of things just inconvenient. Looks like i succeeded in finding the limits of the unopened engine anyway. lol.
I have never seen the temp gauge much over half way, not sure if it overheated or what. I always seemed to catch it in time, lucky I have the informeter... I think it's just the combustion pressure and that is what the VQ35 guys are saying too. Weak ass 3.5 bolts.
Id say you proven the stock vq25 to be very strong so far. I consider the head gasket and bolts the fusible link in an engine and your just tripped.
Yours is still testament to the strength of the factory bottom end. Good job and look forward to the finished result of the 76.
Agreed although it might pay to look into custom head gaskets while waiting for the studs to arrive.
Might as well do it while the top is off.
I can't find any, do you mean copper gaskets or Cometic, apparently the Cometic ones are crap and I doubt they make them for the smaller bore. At least they come in different thicknesses for the VQ35de's though. I have just ordered the stock head gaskets from Nissan but I have to rebuild 2 engines so if you can find a stronger hg option i'm all for it.
Frankly, if the head bolts stretch; even a million dollar gasket won't save you.
At least the Nissan gasket is a known quantity; sort the clamping issue and the problem will likely be gone.
Agree with dale, the cometic ones won't be any better than the stock metal one from Nissan, they are both multi layer gaskets, once shit gets in between them they need to be changed.. The L19's and some new head gaskets from Nissan and it should definitely not be the weakest part in your engine
Scott should shave the head while theyre off :P
higher comp with the 3071 and smaller rear housing would of been sweet and punchy as to drive around the street, but limited to 330-350
but try telling that to these damn horsepower junkies :P
Thing is if you get a bigger (3 or 3.5lt) engine chances are your going to need a bigger turbo then as well, I mean a 3076 is often considered just big enough for an rb30 and nearly all go bigger Gt35s...I think be best just to get a 2.5 up and running again, maybe slightly higher comp for kicks..most importantly sort out the overheating issues...
I may have to get the head decked anyway but they wouldn't be taking much off. I'm keeping the 2.5 for now.
I ordered the oem head gaskets today, and ended up getting the ARP L19 head studs for $399us. They should all be here in two weeks so that's how long I have to get the engine out and disassemble/check it. All going well it should be back on the dyno within a month or so, just got to learn how the pull a VQ down and reassemble it now. :)
well you got plenty of engines to practice on...its just a head job, how hard can it be..
just dont strip any bolts/threads..ended up costing me 130$ to get that little m6 retapped and helicoiled..:( but i had it running 2 hours later :thumbsup:
Ouch, not too bad considering you hacked at it with drill bits for hours though. :)
Thread doctor good to you? He didn't want a bar of my snapped thread with an easy out snapped off in it... I managed it by myself though.
So...under 300awkw should be find right? RIGHT?!?!?!?? no stud stretching for me yeah?
I ask because I plan to flog the hell out of the car in 61 days time....well at least for the 1st month anyway!!! :whistling:
After a visit to Cihan that is...
Edited by ironpaw
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
