I've got a load of parts which were replaced on my R32 GTST from 2003 till March 2011 or in some case were bought to replace a part.
I'm happy to ship interstate so just send me your postcode and i'll get a price.
Pickup available too from Sydney Inner West.
PM or SMS/Call 0404 106 593
Here we go!!!!
HKS Adjustable Heavy Duty Actuator Kit - Brand New - $180
1 x R32 Castor Arm with whiteline bush kit - $20
1 x R32 GTR Blow Off Valve (yes they fit gtst aswell, exit hose is larger) - $50
6 x R33 GTST Stock 16 Inch Wheels (2 x Goodyear F1 Eagle - 20% Left, 3 x Khumo V700 - Shagged, 1 x Rim Only) - $25each or $120 for the lot
1 x R32 GTST Turbo - Removed 2005 - Car Running Stock Exhaust and Boost Distance travelled 87K's - Very minimal shaft play (mint condition) - $130
R32 Stock Dump pipe and stock front pipe - $10
R32 GTST Turbo Water Pipe - $10
R32 GTST-GTS4 Gaurd Liners - $45
Passenger Side Half Peice
Driver Side Half Peice
Passenger Side Full Peice
1set x R32 GTST Stock Suspension - One extra rear included (no top plates included) - $75
1 x R32 Radiator Fan without clutch - $40
1 x R32 Radiator Shroud Lower Plastic Peice - $5
1 x R32 GTST Crank Angle Sensor WORKING - $65
1 set x R32 Stock CAM gears - $15
1 set x R32 GTST Upper Control Arms with Noltec Bushes inserted - made a big difference to steering response Less that 5000kms on these - $100
2 x R32 RB20 Cam Belt Covers - One with RB20 on it the other without - $40 each
6 x R32 RB20 Stock Coil Packs - $45(all)
1 x R32 GTST Stock Fuel Pump with sock - $20
6 x R32 RB20 Red Fuel Injectors - $30(all)
RB20 Stock Cams - In & Ex - $45
R32 GTR Front Brake Lines (94 model) - $15
R32 GTST Front Brake Lines (92 Model)- $5
R32 GTST Stock Airbox, Intake Pipe, Snorkle, Recirculation Pipes (airbox missing some clips) - $50
R32 GTST Airbox Snorkle - $10
R32 GTST Stock Intercooler Setup - Replace with ARC Front Mount - $40
HID Xenon Conversion Kit - H1 Bulbs - 4300K - $80
https://www.sau.com.au/forums/topic/369335-r32-parts-gtst-and-some-gtr/
PRICE DROP
HKS Adjustable Heavy Duty Actuator Kit - Brand New - $160
1 x R32 Castor Arm with whiteline bush kit - $10
1 x R32 GTR Blow Off Valve (yes they fit gtst aswell, exit hose is larger) - $30
6 x R33 GTST Stock 16 Inch Wheels (2 x Goodyear F1 Eagle - 20% Left, 3 x Khumo V700 - Shagged, 1 x Rim Only) - $20each or $100 for the lot
1 x R32 GTST Turbo - Removed 2005 - Car Running Stock Exhaust and Boost Distance travelled 87K's - Very minimal shaft play (mint condition) - $110
R32 GTST-GTS4 Gaurd Liners - $30
1set x R32 GTST Stock Suspension - One extra rear included (no top plates included) - $70
1 x R32 Radiator Fan without clutch - $25
1 set x R32 Stock CAM gears - $5
1 set x R32 GTST Upper Control Arms with Noltec Bushes inserted - made a big difference to steering response Less that 5000kms on these - $85
ttachment=347445:DSC02181.jpg]
2 x R32 RB20 Cam Belt Covers - One with RB20 on it the other without - $30each
6 x R32 RB20 Stock Coil Packs - $40(all)
1 x R32 GTST Stock Fuel Pump with sock - $15
RB20 Stock Cams - In & Ex - $40
R32 GTST Stock Airbox, Intake Pipe, Snorkle, Recirculation Pipes (airbox missing some clips) - $35
R32 GTST Airbox Snorkle - $5
R32 GTST Stock Intercooler Setup - Replaced with ARC Front Mount - $40
HID Xenon Conversion Kit - H1 Bulbs - 4300K - $60
UPDATE
HKS Adjustable Heavy Duty Actuator Kit - Brand New - $160 SOLD
R32 GTST Airbox Snorkle - $5 SOLD
HID Xenon Conversion Kit - H1 Bulbs - 4300K - $30
  • 4 weeks later...
UPDATE
HID Xenon Conversion Kit - H1 Bulbs - 4300K - $30 - SOLD
6 x R33 GTST Stock 16 Inch Wheels (2 x Goodyear F1 Eagle - 20% Left, 3 x Khumo V700 - Shagged, 1 x Rim Only) - $20each or $100 for the lot - SOLD
1 x R32 GTST Turbo - Removed 2005 - Car Running Stock Exhaust and Boost Distance travelled 87K's - Very minimal shaft play (mint condition) - $110 - SOLD
UPDATE
1 x R32 GTR Blow Off Valve (yes they fit gtst aswell, exit hose is larger) - $30 SOLD
6 x R32 RB20 Red Fuel Injectors - $30(all) - SOLD
1 set x R32 GTST Upper Control Arms with Noltec Bushes inserted - made a big difference to steering response Less that 5000kms on these - $85 SOLD
RB20 Stock Cams - In & Ex - $40 - SOLD
6 x R32 RB20 Stock Coil Packs - $40(all) - SOLD
Driver Side Half Piece
  • 3 weeks later...
STILL GOT....
  • 4 weeks later...
AND STILL GOT....
R32 GTST-GTS4 Gaurd Liners - $30 SOLD
Passenger Side Half Peice SOLD
Driver Side Half Piece SOLD
Passenger Side Full Peice SOLD
R32 GTST Stock Airbox, Intake Pipe, Snorkle, Recirculation Pipes (airbox missing some clips) - $35 - SOLD
  • 1 month later...
  • 3 months later...
  • 1 month later...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
