haha i wish, nah it hasnt left the garage, front right quarter and rear bar are good to go, little bit of modification needed to fit the sideskirt with the wide front though. and for the front left quarter...... lets just not talk about that one yet.
UPDATE!!!!!
So Option 1 was gracious enough to send us progress photo's of the wheels and tyres turning up/fitting etc.
After copious amounts of anger we finally got the spoiler off the boot. (3 bolts(w/ Loctite), 1 massive 1-way clip and about 4 litres of glue) pinch.gif
And Test Fitting the rear bar
Test fitting front right quarter (bolted on now)
Doin more every night, so ill try to update soon.
***UPDATE***
Here's some pics of the progress so far.
Let us know what you think!
@WHITE gtt
Hey mate, only go the viva kit if u have some awesome glassing skills, if u can modify it urself then viva kits are fine. The old saying 'you get what you pay for' does come into play once again though. In this case I'm blending the rear quarters into the body.
they seem to be very hit and miss with there products. i had an old viva kit. rear bar was the only thing that fitted no mods. skirts were miles out.
ive since had mates get bits and pices. some very good otheres not so.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
