Not sure if this will be helpful, but this is a high octane sump on an R34 engine on an R34 crossmember with Nismo mounts. Plenty of room as you can see. But dropping the engine further by lowering the mount positions on the subframe, or re-drilling the alloy mounts so they mount higher on the block would definatly have at least 10-15mm of sump extending below the flat section under the crossmember. So there would be no protection for it should you hit something on the road, speed bump... or whatever.
Your 10lt CRD sump might afford you some options though, as you could remove that 10-15mm from the bottom of the sump and sacrifice a little oil capacity to allow the engine to be dropped further. 7lt is plenty with a trap-door sump and the propper sized oil restricters in the head.
no thanks for that pick is of some help.me and a mate spent some time on it today just trying to place things and see what is going to fit and what wont.the clutch master will not fit so ill hunt down one that will but i will have to relocate the fluid bottle as the fire wall does sit in alot there.
the car has after market sway bars on it but there only a small amout larger but i hope i can still get the engine low enough so is does not hit the bonnet.but after today i think im getting closer so just a matter of time and parts now.worse case i just get a carbon ztune bonnet and cut that to fit
  • Replies 204
Best buy a nismo Z-tune bonnet will give you heaps of room as i have checked the difference from the china Z-tune bonnet to the Nismo Z-tune Bonnet , Nismo one has about 10mm more clearance.
Not sure if you have read my build on here R34 gtr build - Jem Dyno
  • 1 month later...
done a small amount of work on thursday night
drilled out the head oil drain back holes to large size.
worked out the 4wd sump adapter (awesome quality kit) seems fairly simple to do once you read the instruction manual and spend some time working it out.
hoping to start on the adapter tommorow and get that finished so the building can begin :D
photos of semi-preped half concrete filled rb30 block will attack with grinder tommorrow to fit adapter.
The pile of parts from old engine and parts for new engine....JUN stroker crank sitting there in perfect condition that someone should buy.
cool, what sump adapter did you go with?
mmm, yes I like the jun crank. I have one in my car at the moment. the jun 2.7 crank but running tomei rods and pistons. it's surprisingly different to the other 26s i've had. maybe I need a spare? lol.
Hey mate,
I 26/30'd my bnr34 and didn't have many clearance issues. The front of the timing cover *just* clears the bonnet, but presumably under acceleration it is touching as I do get brown marks from the bonnet underlining on the timing cover. I didn't need to put spacers between the chassis and cross-member to clear the sump with the adapter. The rubber intercooler hose that attaches to the intake will also stretch, although I've since replaced mine with Greddy cast pipes.
About the only other concern I had was the fact that as I was running a high mount turbo, it became the highest point in the system; so after engine shut down water would sit inside the CHRA and boil, which eventually (I'm talking 6 months+) perishes the coolant lines and causes them to crack. One day I'll get around to installing a proper breather tank, but it's okay for now =)
If there's anything else I can help with shoot me a PM!
APHID:
what intake manifold are you running? we are going to have issues with the clutch master fouling on the hypertune intake so we are trying to get around that.
we have to run the spacers unfortunetly due to bigger the factory sump we have no clearance to play with.
UPDATE:
Block is finished ready for degresing cleaning and spraying. reliefs cut out for sump adapter. They aint pretty but they work.
Head is at machine shop to get valve clearances setup for the cams.
bearings should be ordered tommorow rings be here start of next week. Then the assembly can begin :D
Ignoring the awesome saftey equipment...or lack of.
Pro engines sump adapter. Awesome bit of kit worth every dollar.
Expensive box of valves.
RB30 crank ready to go begging to be stressed.
Various parts from old engine getting reused.
WEAK STOMACH PEOPLE LOOK AWAY NOW. I take no responcibilty for the follow condtions.
And last but not least the fuel for the builders
Hey mate,
The engine mounts are attached to the Xmember, so no matter how far you space it, wont make any difference with sump clearance,
if you did this mod, you would of had more clearnace between your touching bonnet and timing cover though
correct jangles. we might have to space the engine from the mounts aswell as spacers in x member. We cannot remember how much clearance between the bigger sump and thicker swaybar there was. One of those little issues that we foresee being a nightmare
Edited by nick81xd
Dont really wanna start cutting into the sump as its a good capacity (9L) and with the baffle gates inside wil be a pain to move them up. Find out when we are slotting motor back in might be able to work a fix.
Exhaust im not too sure on but its been modified to the job, tim might be able to shed some light on brand. the intake is a good old Hypertune manifold.
the exhaust manafold is hks as it was bought as a full t51r kit
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
