Not sure if this will be helpful, but this is a high octane sump on an R34 engine on an R34 crossmember with Nismo mounts. Plenty of room as you can see. But dropping the engine further by lowering the mount positions on the subframe, or re-drilling the alloy mounts so they mount higher on the block would definatly have at least 10-15mm of sump extending below the flat section under the crossmember. So there would be no protection for it should you hit something on the road, speed bump... or whatever.
Your 10lt CRD sump might afford you some options though, as you could remove that 10-15mm from the bottom of the sump and sacrifice a little oil capacity to allow the engine to be dropped further. 7lt is plenty with a trap-door sump and the propper sized oil restricters in the head.
no thanks for that pick is of some help.me and a mate spent some time on it today just trying to place things and see what is going to fit and what wont.the clutch master will not fit so ill hunt down one that will but i will have to relocate the fluid bottle as the fire wall does sit in alot there.
the car has after market sway bars on it but there only a small amout larger but i hope i can still get the engine low enough so is does not hit the bonnet.but after today i think im getting closer so just a matter of time and parts now.worse case i just get a carbon ztune bonnet and cut that to fit
  • Replies 204
Best buy a nismo Z-tune bonnet will give you heaps of room as i have checked the difference from the china Z-tune bonnet to the Nismo Z-tune Bonnet , Nismo one has about 10mm more clearance.
Not sure if you have read my build on here R34 gtr build - Jem Dyno
  • 1 month later...
done a small amount of work on thursday night
drilled out the head oil drain back holes to large size.
worked out the 4wd sump adapter (awesome quality kit) seems fairly simple to do once you read the instruction manual and spend some time working it out.
hoping to start on the adapter tommorow and get that finished so the building can begin :D
photos of semi-preped half concrete filled rb30 block will attack with grinder tommorrow to fit adapter.
The pile of parts from old engine and parts for new engine....JUN stroker crank sitting there in perfect condition that someone should buy.
cool, what sump adapter did you go with?
mmm, yes I like the jun crank. I have one in my car at the moment. the jun 2.7 crank but running tomei rods and pistons. it's surprisingly different to the other 26s i've had. maybe I need a spare? lol.
Hey mate,
I 26/30'd my bnr34 and didn't have many clearance issues. The front of the timing cover *just* clears the bonnet, but presumably under acceleration it is touching as I do get brown marks from the bonnet underlining on the timing cover. I didn't need to put spacers between the chassis and cross-member to clear the sump with the adapter. The rubber intercooler hose that attaches to the intake will also stretch, although I've since replaced mine with Greddy cast pipes.
About the only other concern I had was the fact that as I was running a high mount turbo, it became the highest point in the system; so after engine shut down water would sit inside the CHRA and boil, which eventually (I'm talking 6 months+) perishes the coolant lines and causes them to crack. One day I'll get around to installing a proper breather tank, but it's okay for now =)
If there's anything else I can help with shoot me a PM!
APHID:
what intake manifold are you running? we are going to have issues with the clutch master fouling on the hypertune intake so we are trying to get around that.
we have to run the spacers unfortunetly due to bigger the factory sump we have no clearance to play with.
UPDATE:
Block is finished ready for degresing cleaning and spraying. reliefs cut out for sump adapter. They aint pretty but they work.
Head is at machine shop to get valve clearances setup for the cams.
bearings should be ordered tommorow rings be here start of next week. Then the assembly can begin :D
Ignoring the awesome saftey equipment...or lack of.
Pro engines sump adapter. Awesome bit of kit worth every dollar.
Expensive box of valves.
RB30 crank ready to go begging to be stressed.
Various parts from old engine getting reused.
WEAK STOMACH PEOPLE LOOK AWAY NOW. I take no responcibilty for the follow condtions.
And last but not least the fuel for the builders
Hey mate,
The engine mounts are attached to the Xmember, so no matter how far you space it, wont make any difference with sump clearance,
if you did this mod, you would of had more clearnace between your touching bonnet and timing cover though
correct jangles. we might have to space the engine from the mounts aswell as spacers in x member. We cannot remember how much clearance between the bigger sump and thicker swaybar there was. One of those little issues that we foresee being a nightmare
Edited by nick81xd
Dont really wanna start cutting into the sump as its a good capacity (9L) and with the baffle gates inside wil be a pain to move them up. Find out when we are slotting motor back in might be able to work a fix.
Exhaust im not too sure on but its been modified to the job, tim might be able to shed some light on brand. the intake is a good old Hypertune manifold.
the exhaust manafold is hks as it was bought as a full t51r kit
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
