No! Bad Nankangs! :domokun:
Had them on my N14 SSS, previous owner put them on. Would never, ever recommend them to my worst enemy!
Did I mention... No! Bad Nankangs! :domokun:
well to my worst enemy i might lol
Nankangs FTW....they don't wear out!.....probably because they are made of a harder compound than the road they roll on!
I totally agree they are one of the worst tyres for grip that you can buy new......but sometimes that can be a good thing!ninja.gif--------> heads to youtube for another laugh of the stall and launch!
I went to a trade show recently; showcasing all kinds of new automotive technology; You're all piling shit on them, but you should see the new offerings from Nanakang!
And their new Performance offering; post-61153-0-83736800-1309475227_thumb.jpg
hahahahahaha
Agree.
I am just about to replace my set for the first time... that originally came with the car!
Yes, that was 140,000kms ago lol
Agree.
You can't complain about value for money with that distance travelled, amazing! I'd put up with lower grip levels if i was to get anywhere near that wear out of a set.
My Toyos have worn the insides at the back as well. Had 2 wheel alignments in 10000km. Might be time to get a 2nd opinion
ive had my car 2 years, same rubber since i put the 18s on, the inside rear has NOT worn out and its been aligned only once since i got it. and that was after the coilovers were installed.
I should not that the Nankangs + stock 17's were not on the car for ~30,000 of those kms.
Still, over 100,000kms from a set of tyres...
I would be ecstatic if I got half that distance on a set. Didn't think it was possible actually.
I need to buy tyres in the next few weeks & you've convinced me to ask around for someone who knows how to align a M35 properly.:thanks:
  • 10 months later...
I could send you my last alignment results but they might not mean anything unless your car was exactly the same setup as mine (height wise etc).
Coincidentally I took my car in for a 5000km tyre checkup today (I was expecting another alignment & rotation) but was told to leave it another 5000km as there wasn't enough signs of wear to warrant any changes.
Leon, the amount of toe & camber from your alignment will be applicable, regardless of differing ride heights.
Throw the specs on if you can, if you're not scrubbing the soft Invo's; it must be on the money.
Leon, you have the toe and camber bolts though, right?
So may not be completely useful?
Good news. Still liking the Nittos?
Yeah Ryan, they impress me in different ways nearly every time I go out. Torrential rain today & it was like driving an 'ordinary' car in the dry. Wear rate could be the one thing that fails, but I won't know for a while yet.
I didn't think that would be the case, but I'll believe you. Suspension is still smoke & mirrors to me, lol.
Current FRONT specs:
Toe-in: LH 0.5mm, RH 0.5mm Total toe-in 1.0mm
Camber: LH -1.8 deg, RH -2.3 deg*
Castor: LH 6 deg, RH 7 deg
Current REAR specs:
Toe-in: LH 1.0 deg, RH 1.0 deg
Camber: LH -1.8 deg, RH -1.8 deg
* The RH camber is a potential problem. Pretty sure the Superpro upper camber kit (from Ryan's GB) will be used to reduce that figure by 0.5 deg.
I'll try to update this as my alignment guy feels his way. I've been to 2 or 3 other shops in town with no joy & at least this guy is prepared to follow through until he gets it right.
BTW, in reference to earlier posts in this thread, I also run my tyres at 40+psi.
Edited by Commsman
I got mine aligned the other day too.
Rear
Camber Left -1.04'
Right -1.00'
Total toe +1.8mm
Geometrical driving axis +0.05'
Front
Camber left -0.27'
Camber right -0.31'
Individual toe left +0.8mm
Individual toe right +0.7mm
Total toe 1.5mm
Castor left +6.32'
Castor right +6.32'
The wheel aligner said I should get the left castor on the front up to 7.0' to stop a bit of pull to the left.
  • 4 months later...
It makes me crazy /laugh when I read the first comment on this thread! So many tyre places and so called alignment guys are full of crap. Tyre guys give uneducated opinions based on NOTHING. just personal opinion. The front and rear are FULLY ADJUSTABLE so you can set them up perfectly for "australian"roads.
I have an educated opinion at least (15 years as tech engineer for Bridgestone and an engineering qualification) and we know our cars. Firstly if you can find the specs, use them. SOme vehcicles are a little different due to design (eg 350Z need more toe in because they have toe out issue under braking) or F/R balance - some FWD run more rear neg camber to give rear bite... but as a general rule: Set them up to suit your dirving needs and roads. eg i drive flat freeway but still want a bit of neg camber for cornering - so half to 1 degree of neg camber, put a bit of toe in for movement of bushes, under braking and wear (1mm measured on the right tyre /wheel diameter).
Re tyre pressures, if you are running 45 series or lower put 40 psi because they are easily damaged if they get a little underinflated. esp if they are subject to excessive camber. the lower the aspect ratio - the more pressure for safety (up to 45). I run 38 in my 50 series, I would not go under 34.
Re tyre wear, how long is a bit of string? depends on alignment and driving. I will get at least 45000 out of mine because I do a lot of freeway. You get what you pay for with tyres. Nankangs and wanlis etc just dont have the balance of grip and wear and are really bad at recovery (slalom). I remember testing wanlis on a reps HSV. I nearly lost the rear end by the 3rd cone and had to abort at 70km/h whereas Bridgestones did 80km/h and just kept going where I pointed them - no snap oversteer no wash - just grip.
But if you like power oversteer coming on easily, and dont mind fighting for your life dodging a kangaroo or animal when the tyre wont recover, go for the wanlis!
i took my car to pedders for a check up about a month ago i thought the inside rear edges were wearing because i have -2 degrees of camber but the guy reakoned it shouldnt wear like that and that my rear front X'member bushes were flogged.
but ive gotten over a years worth out of them and i think about 25,000km so im not complaining really.
