Can't wait to smash that turn 1! In the mean time everyone should be praying to the sun god and doing these weird stances http://www.harekrsna.de/surya/surya-names.htm
ineradicable!
Word of the day, possibly week. Yeah definitely week.
  • Replies 140
Can't wait to smash that turn 1! In the mean time everyone should be praying to the sun god and doing these weird stances http://www.harekrsna...surya-names.htm
You talking about turn 3 just before Honda?
Lol Jack I know its been a while but....
For those that haven't been there before (or the details have slipped their minds ;) ) click here for the map:
http://www.phillipislandcircuit.com.au/map.html
...oh and Jack make sure you go left when leaving the pits :D
On the streeter tires it is near impossible to have the car out that wide around southern. That line has the best corner exit speed, but the poor streeter just push you wide.
It is hard enough to get the car to turn on this line, any wider you end up in the sticks.
That was a very nice lap.
So with the double apexing of the Southern Loop - you reckon guys on street tyres shouldn't even try it - it is because of all the rubber marbles on the outside.
I have Dunlop Direzza's Z1* - I got no idea if they'r any good. If anybody has any idea what pressures I should run I'm all ears - thanks in advance.
Baron rates the Z1's. I have never had them.
34-36 hot I would think.
I find with my car that any wider in the loop and you loose front grip very quick. But with the GTR you have the front wheels pulling the car into the corner.
This is a mates GTR on the same as my vision on the same tires.
driver training will by CAMS rules be all in one group = 5
(what is up on my froums i am still playing with)
Even if people haven't put themselves in Driver Training but have a CAMS licence starting in 111 and havent given any experience they end up in Driver Training as well.
That extinguisher thing wont go away will it., The upgrading is in process and we are doing it to help people come up to speed before its locked down.
I am looking forward to the Speads as well and we have another clubman now.
Wow that is an impressive list of entries in group 1 :D R35 GTR, GT3 porshce, Speads RS08, Takwalai's falcon, Jesus, Ant, Luke.... Oh, and then there's that 240z with an RB26... I'll be staying out of his way if i see him coming :ph34r:
Not to mention Dale's VZ commodore looking to break into the 1:30's. Great variety of fast cars, let's hope the weather plays nice....
Hey Jack - you wouldn't happen to have any old GT-R fitment 18 x 10.5's laying around unused I could borrow for a day?
Unfortunately I only have the LMGT4's that are on my car at the moment, have got rid of all the rest of wheels I had in the past. I'm assuming you have tried Aaron at IM?
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
