Can't wait to smash that turn 1! In the mean time everyone should be praying to the sun god and doing these weird stances http://www.harekrsna.de/surya/surya-names.htm
ineradicable!
Word of the day, possibly week. Yeah definitely week.
  • Replies 140
Can't wait to smash that turn 1! In the mean time everyone should be praying to the sun god and doing these weird stances http://www.harekrsna...surya-names.htm
You talking about turn 3 just before Honda?
Lol Jack I know its been a while but....
For those that haven't been there before (or the details have slipped their minds ;) ) click here for the map:
http://www.phillipislandcircuit.com.au/map.html
...oh and Jack make sure you go left when leaving the pits :D
On the streeter tires it is near impossible to have the car out that wide around southern. That line has the best corner exit speed, but the poor streeter just push you wide.
It is hard enough to get the car to turn on this line, any wider you end up in the sticks.
That was a very nice lap.
So with the double apexing of the Southern Loop - you reckon guys on street tyres shouldn't even try it - it is because of all the rubber marbles on the outside.
I have Dunlop Direzza's Z1* - I got no idea if they'r any good. If anybody has any idea what pressures I should run I'm all ears - thanks in advance.
Baron rates the Z1's. I have never had them.
34-36 hot I would think.
I find with my car that any wider in the loop and you loose front grip very quick. But with the GTR you have the front wheels pulling the car into the corner.
This is a mates GTR on the same as my vision on the same tires.
driver training will by CAMS rules be all in one group = 5
(what is up on my froums i am still playing with)
Even if people haven't put themselves in Driver Training but have a CAMS licence starting in 111 and havent given any experience they end up in Driver Training as well.
That extinguisher thing wont go away will it., The upgrading is in process and we are doing it to help people come up to speed before its locked down.
I am looking forward to the Speads as well and we have another clubman now.
Wow that is an impressive list of entries in group 1 :D R35 GTR, GT3 porshce, Speads RS08, Takwalai's falcon, Jesus, Ant, Luke.... Oh, and then there's that 240z with an RB26... I'll be staying out of his way if i see him coming :ph34r:
Not to mention Dale's VZ commodore looking to break into the 1:30's. Great variety of fast cars, let's hope the weather plays nice....
Hey Jack - you wouldn't happen to have any old GT-R fitment 18 x 10.5's laying around unused I could borrow for a day?
Unfortunately I only have the LMGT4's that are on my car at the moment, have got rid of all the rest of wheels I had in the past. I'm assuming you have tried Aaron at IM?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
