I recently bought a HKS dump-pipe.
The pipe has no heat shielding, and I am concerned that the radiated heat will have an impact on hoses and
the engine bay in general.
Any suggestions how to control this?
Is this exhaust wrap (cloth) any good?
Personally I don't like the looks of it but can not think of an alternative ..
Any suggestions?
Thanks ... :)
https://www.sau.com.au/forums/topic/370896-heat-wrap-foil-what-works/
Wrapping works well to keep the heat in the pipe and not in the bay, but it can lead to the pipe corroding and/or cracking. This depends on the material used, how well it is welded and braced/loaded etc. The corrosion can be due to the wrap gettign wet then staying wet (doesn't happen often because usually when it gets wet it's hot because you're driving.)
By far a better option is to get it coated by HPC or equivalent. If you do this on the outside, then the metal of the dump will run hotter so you can sometimes get some of the same failures that you see with wrapping, but perhaps less often. If possible, then getting coating on the inside also helps to keep the heat from actually transferring to the metal of the dump, which is doubly good. Not easy to do and not guaranteed to stay coated either, under the horrible conditions found in there.
Your other option is to use some ACL heat shield material or bend up some stainless sheet and mount heat shields in such a way that they lie between the hot dump and anything you don't want cooked. Best not to mount the shields off the dump itself. Best to mount them off other locations. The OEM heat shields are of course all attached direct to the manifold/turbo/dump and the attachment points transfer heat to the shield, but they're still better than nothing, so if you get desperate you can use a stainless hoseclamp or two to hang shields off the dump.
I didnt find my exhaust had any affect on under bonnet temps at all. Maybe if you are sitting still, idling for a long time then it will get hot. But otherwise the air flow while you are driving keeps things pretty cool.
Hi there,
Thanks for the replies and ideas ..
I will work something out, but even if the heat is transported away while driving there will
be heat soak when you park the car.
The car is also moved in the city and in London you are stuck alot in ridiculous traffic :(
(though I try to avoid this)
Exhaust wrap works a treat...don't worry too much about so called cracking and corrosion and what not...its not going to disintegrate in a week...the hks dump pipes are made very well and will outlast the car most likely...
Wrap it, if it cracks in a coulpe of years get a new one and wrap that, also efective tape/shielding on local parts works for me.
Wet it first and wear gloves and long sleeves, that s hit is itchy.
Hi!
Yes, the HKS is stainless steel .. I wanted to have something which outlasts the car ;)
It's a nice piece of hardware but the location of the lambda-sensor is awkward ..
I will try the wrap (since it seems to be easy to apply and is also not expensive)
Many thanks ....
Snice we're on the topic.....
I have a aftermarket matched length dump pipe for the twins that pass very close to the gearbox and I was thinking about wrapping it to avoid heating up the box.
What i want to know is should I wrap just this one pipe alone, or should I wrap the both to keep the temp similar in both and therfore velocity? and all that simmidimmi ?
wrap both, put a shield on the gearbox itself.
Ceramic coating is awesome and cost roughly the same as good quality heat wrap. The shop near me does ceramic coating for dump pipes for $100.
Skylines do run quite cool compared to some other cars. My uncles R8(modded a little) runs quite warm you can feel it.
My brothers car had a tissue touching the dump.... It caught fire.... Its a rotor. It was quite funny, we were like what the f**k is all this smoke. Then you see a tissue smouldering. To note, the car was not driven, just idling in the drive way for about 3 minutes.
My input is it does make a difference. Ive sat passenger in my both my skylines a couple times. My old skyline was heat wrapped the whole way to the muffler(overkill?). This one is only wrapped on the cat back. I can tell you there is a definite difference in passenger footwell temps esp on longer drives.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
