6766 is a 950hp turbo, I don't think the 1300's would make it.
I would go the EV14 2200's (at high pressure) and run a 10 micron inline paper fuel filter. I have seen too many block up recently.
I've seen advertised on eBay a kit for the RB25 including 1000cc Bosch injectors for US$700. Comes with injectors, rail, plug adapters, and a FPR if you pay "buy it now" price. And supposedly will fit under the stock plenum.
Seems to be too cheap for what's included:
http://www.ebay.com.au/itm/Nissan-Skyline-RB25DET-r33-GTS-T-1000cc-Bosch-Fuel-Injectors-Kit-Fuel-Rail-/200968949936?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ecaaed0b0&_uhb=1
I have the 1300s in my car, it is hopefully getting tuned this week, RB2630 with GT-RSs, hoping for 600awhp, my tuner is removing alot of the 2000s in favour of the 1300s if the 2000s where just used cause the 1000s weren't big enough, he has said the 1300s are alot nicer for street use
^^ Been looking at the same kit. It's $820 Au with shipping, but still seems to be a good price.
Agreed. What I was worried about is; is the price too good? Wondering if they're knock off injectors or something. Says they're genuine, but...
It'll be interesting to see how much better the 1,300's are. The 2000's I wouldn't consider grumpy at all.
They are just as cheap locally, with local warranty and support. Why bring them from the other side of the world?
This ^^
I hear Bosch may be using the ID stainless internal technology on a new 1700cc injector or something, it is in development I was told. ;)
The 2000's will idle fine.
For that power don't bother with the 1000's, Unless you are willing to run 100psi fuel pressure. Just get the 2000's, they will be fine for years.
The other option if you have the cash is the Moran's...
http://www.injectorsonline.com/indivprod.php?cid=110
Best damn injector out there! You can pull them apart yourself and clean them if need be. All stainless outside and inside apart from the plastic injector plug body. These babies will last you a lifetime. We run on methanol and went through 4 sets of ID 2000's before learning our lesson. The 2000's are not alcohol tolerant. The internal seals are rubber and swell over time and the injectors flow is severely reduced. Result is melted spark plugs and pistons!
If you look at the quality of the product you are getting for the price, they are actually quite cheap in comparison.
Do you think 1300's will make 600rwhp on e85?
My 1200's are making 708rwhp on E85 (on their limit) so no reason why 1300's shouldn't piss in 600
I know a lot of people who are having issues with blocked EV14/ID2000s on Ethanol, we are just using the Deatschwerks 1200cc drop in GTR ones now as they seem to be hassle free
I think the built in filter inside the injector is getting blocked by the fine black carbon floating in the fuel, as it is finer than most injector filters, possibly as it's a gas injector. (Specifically the ID2000's for some reason) I have had no issues with my Xspurt 1000's and I have put a LOT of fuel through them over the years.
I now suggest to customers they run a high flow 10 micron paper filter before the rail with 2000's. Moran demand 10 micron filtration for their injectors on Ethanol fuels, or the warranty is void.
6 x Xspurt 1000's and Proflow RB25 rail would be around $800 through me I think Mark, with all adapters.
Scotty - will that rail fit with the stock plenum? We are looking at going to E85 in the next few months, so I am interested in an injector upgrade.
What paper filter are you using, I was told to be careful when use paper filter cause the ethanol can/does eat away the "glue" that holds the filter element to the casing
I'm using a speed flow 10 micron stainless sceen filter but the paper ones can go down to 5-6 micron which would be better
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
