As part of our track testing and development of GTR parts at Willall Racing one thing we have done is overpowered the standard braking system. In 12,000 miles we have exhausted 5 sets of brake rotors and around 15 sets of brake pads, and in the middle developed a water cooling system - WR35WS - which has helped us and many others around the world keep a longer and stronger pedal and nearly double pad life. The problem being - the faster you go and the better tyre you have, the more brake you need....
We chose the Endless braking system for R35 for a couple of reasons. Firstly we needed a stiffer and stronger caliper. We were losing 30% of pad life at least with the taper - in both axis - in pad wear with the standard caliper. Secondly Endless offer a bigger rotor, titanium piston, and super thick (double the thickness of stock GTR) brake pads. Its part of their Super Taikyu endurance program, so lets get them on....
This weekend we are testing at the track. We have an existing benchmark with the stock braking system on AP J-Hooks/stock calipers, we are using the same Advan 20 inch slick tyre set, and the weather conditions look to be similar. Yes we have developed a WR35WS water injection setup for these bad boys as well. In my experience on the matter, nothing suits a race track better than a race brake...and I cant wait to put this Endless Mono-6 setup to the test and see how it stacks up against the Brembo competition setup on our Porsche GT Car :cheers:
https://www.sau.com.au/forums/topic/372284-serious-brake-upgrade/
wow, massive number of vanes in those rotors! I'm guessing they pump a fair bit of air.
the calipers looks nice and very 'reminiscent' of alcon and the current generation brembos... even the font is very brembo...
yeah nothing adds confidence like brakes that perform stop after stop.
84 vane rotors.
Combined with our water injection system they should be the business :)
(I have always loved Endless gear, it just works so well)
New Endless Mono-6 system was awesome at EC :)
As for the water? It turns to steam before it really even contacts the rotor so there is no evidence it has even been there apart from a very cool rim (or at least not red-hot) when the car comes back into the pits....
Will check on the piston area with Endless.
Hello Martin. Is this the same as the kit developed for the HKS R35 GTR? Looks very similar. Also didn't I read somehwere you had already done a ceramic brake upgrade instead?
Cheers
Marty
If you have the OEM Brembo calipers there that is piston area I would like to know... thanks Martin.
Good to hear they worked well :)
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
