Question about the AASA license requirement, since it's Calder... will they accept CAMS license holders as sufficient or do you explicitly require AASA license as well?
Usually CAMS is accepted by AASA. I only have CAMS L2S
Did anyone see channel 31 last night? lol, fail.
Do tell...
  • Replies 195
Is 'The EVO' the blue one?
Scotsman was faster than it at the test day because the thing was too laggy for this circuit. It was off cam coming out of all the chicanes. Much like it would be at Haunted Hills. A fast Haunted Hills car will be fast on this track more so than a fast Eastern Creek car.
Anyhoo - my car is still in bits so I'm out. Bummer too as I was keen for a crack at the Tuner Class as my new tyres are here and good to go.
Yep Saturday @ Sandown.
Was there last weekend too.. I think I might have a problem :D
PI with PIARC and Sandown with Masser coming up before Nats as well thumbsup.gif
Track Battle guys were going to be on that C31 RMIT motor review show, but didn't turn up. So the show bagged em out and moved into something else.
Hang on a sec Martin, where you looking to see the name Bryce?
I cannot see it on the site under Street Class:
http://trackbattle.com.au/trackbattle/drivers-teams/round-1-calder-park-thunderdome/street-class/
So that guy was removed buy Russ and stuff wasnt added - poo lol :(
Either way gonna be a fun event.
I'll bring an esky along with some soft drinks etc.
Anyone wanna volunteer to bring something else?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
