  • Replies 130
i cant tell you how annoyed i am to miss tas this year,my gallbladder has to be removed after xmas ,damm gallbladder,so hope everyone has a great time,and for those who havent been before you will have a blast ,you wont be able to take your eyes off the japanese promo girls
https://www.sau.com.au/forums/topic/37474-tas-2005/page/6/#findComment-1094998
Would anyone mind two more people tagging along? My brother and I will be vacationing in Japan in January and one of the highlights of our trip will be going to the TAS. We will be leaving from California U.S. and will be in Japan Jan. 11-19.
We're planning on staying at the Shiba Hotel (same as CircusMonkey :()
Since this is our first trip out there, we plan on doing a bunch of toursit stuff, so we shouldn't be much of a bother to you guys.
https://www.sau.com.au/forums/topic/37474-tas-2005/page/6/#findComment-1095795
Thats ok, for sure.
I'll put you down for the Saturday then? Thats when most people are going.
https://www.sau.com.au/forums/topic/37474-tas-2005/page/6/#findComment-1095805
Hey, I will be going too with my gf and another of my mate with some of his friends from Singapore. Think I stated in another thread but I'm being missed out in this thread!!
Arrival Narita 13th Jan, Departure 17th Jan
Still awaiting confirmation for hotel room at Shinjuku Vintage (AU$110). Anyone has better recommendations on pricing and the proximity nearest to Shinjuku?
Will be visiting TAS on the Sat for a day only due to tight schedule as I'm doing some usual tourist rounds.
Will be super duper grateful if anyone can let me in on the garages and workshops visit list and also the itinerary for Sat.
Cheers
https://www.sau.com.au/forums/topic/37474-tas-2005/page/6/#findComment-1117151
Flying into Narita on the 8th, Sapporo on the 9th, pack container, Tokyo on 12-13th, Nagoya auctions 15th-16th home 17th. I ask myself when am I going to get a holiday??
CU there.
Ken
https://www.sau.com.au/forums/topic/37474-tas-2005/page/6/#findComment-1121164
Hey Blitz,
I will be staying at the hotel (new T) on the 14th, we fly out the next day so Friday is the only day I can have a look around. What are you guys up to on Fri??
Ken
Hi Ken,
Nick (blitz) and I are travelling to Japan together. I don't know yet what Nick has planned for us yet on the friday, but I'm sure we could meet up at some point. See you there.
Richard
https://www.sau.com.au/forums/topic/37474-tas-2005/page/6/#findComment-1125170
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
