I was speaking to AVO and they said they still sell plenty of their housings so someone must like them..
They are not ideal though and you dont really save alot of money doing it.. so i wouldnt recomend it..
A 400-450hp compressor is all I would throw at it.
yeah my custom Rb25 highflow turbo, built by ATS Adelaide Turbo Services, utilises the AVO .73 rear housing matched to a stock V45 Nissan comp.housing (machined out) with gt3076iw ball bearing core. Rated to around 280rwkw at ~19psi, capable of 22-23psi, and made to look like the Stock Standard turbo.
The AVO exh.housing works well for the application it is intended for. 250-280kw range, auto or manual, bolt-on option.
I wonder wht the .73 housing flows less than the .63???:glare:
Anything that bolts up to the stock dump pipe is a compromise for the 60mm turbine. There has been disappointment from these housings in terms of their power they make at the top end. So while you feel like you are saving some money on the front end you may end up with an expensive lesson if the results aren't what you want.
The GTX3071 'on paper' will make similar power to the older 76mm GT compressor but history has shown that the AVO will probably max out before the compressor has done its best.
The ARR is just what it sounds like and area radius ratio so there is not much joy in comparing the 0.73 to a garrett 0.63 or 0.82 GT30 framed ARR. The 0.73 seems to flow less than the 0.63 (The Mafia has done more to max out a 0.63 than anyone if you search for it).
I think you will get better results if you suck it up and change dump pipes and use a native garrett housing.
Hypergear results recently are showing some really good results that are very similar on paper to HKS2835ProS, plus the Kando Dynamic turbos also are producing good numbers at great prices but also require a little bit of fiddling around, like a Garrett turbo, the first time you install one.
If you are committed already I would ask if you can change to the Garrett turbine housing instead.
Already answered, the number is the area radius ratio. If the area and/or the radius is different then.....
You are not comparing two GT30 based turbine housings.
So I take it you are going with a non-garrett housing then?
yeah thats what i paid for mate so ill just bite the bullet and see how this setup goes :thumbsup:
yeah mate im hoping you will be around to see what the end result is too :thumbsup:
this is my first RB and i havent driven a skyline with a bigger turbo before so i wont be able to make a comparison to anything else
im sure what ever the power figure ends up its gunna feel much more lively than the 203kw i have now!:nyaanyaa:
HOPEFULLY IM SATISFIED FOR A WHILE ANYWAYS! HAHA
For comparisons sake, here is a picture of my GTX3071R's 5 bolt rear:
see heres a pic of mine old tech 3076 comp with the modified .64 skyline rear..
i can smash the pedal in any gear at anytime and it goes hard
compared to stock
you can almost see by the size of it its going to choke..It is still very quick on the street with full boost 19psi around 3500 and the small housing does give great response it drops to about 17psi by 6500rpm though, as do most IG and once you get in the upper rev range over say 5500rpm it just isn't as exciting as it should be.
Its making around 240kw @ 19psi which is alot of boost for not much result, but it is an old tech compressor. A new GTX one would make more but not much, 260 maybe, tangles makes 250kw ,if i played around with cams and gears etc it might make more, but I'm not going to bother as its easier to just swap it completely..
its still good fun and very driveable on the street with stock like response. The bit of extra lag it does have helps stop it form stepping out or losing traction to early, so its actually quite well balanced in an unbalanced kind of way :wacko:
The housing is much bigger I do prefer the look of the wastegate being separate on the garrett housing too but oh well its a done deal now so see how it goes when she is bolted in an all tuned up with with my hks cam gears and timing belt
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
