Fantastic result. Bit better than my 268kws. When does it feel like it's running out of puff, revs wise. Mine starts to feel flat after 5,500rpm just like the hi-flow I had from GCG. Which was a crap turbo by the way. Wasted a couple of grand on that one trying to get it over the 23okw mark. I have done 308,000k's in my car so I hope you look after yours and have as much fun as I have. Mind you, I'm on my second engine and 2nd gearbox and 2nd diff and 4th clutch, but hey, don't worry about all that. Engines are cheap so make sure you enjoy it.
A couple of tips. Replace your coils around every 140,000k's. Just replacing my 2nd set again now. You will need to replace all the relays attached to the engine loom and coils at 300,000k's or before if the car is thrashed on hot days alot. Heat is the enemy. I have replaced the coil harness just now and it fixed a little miss in the top end. Have alook at engine mounts and gearbox as well, they will let go in spectacular fashion if left with any defects from constant cicuit work. So many things to do so I'll stop before I make myself stress. :yes:
*cough* I near sprayed my computer with coffee, my gt3071 sr20 curve is nearly identical, even peak power. I won't post it as i don't want to take away from micks results as that is awesome for a .63 IW on a stock manifold. No boost control issues either which is a relief.
Out of interest, what boost controller do you run mick as i would have thought it would hit full boost a lot sooner (under 3k) based on my old rb25 results.
Your setup is wayyy different, this is bolting on a turbo, intercooler, injectors and afm to a stock setup. Not fair to compare.
Full boost under 3000rpm is ludicrous on this type of setup. Even the most responsive of turbos that hit the ceiling at 240-250rwkw cant make 20psi by 3000rpm.
It's doable. 2 of mine when i was trying to get it right on the rb25, unfortunately not showing 20 by 3k in either of these as we were battling boost control issues. On road it would crack 20psi by 3k in 4th on a flat road easily.
Same basic setup as Mick's but with a .63 and a set of drop in cams.
I heard you might be looking for a turbo, liz, I'll pm you the sr results
edit: the bottom one was boost control via the right foot so not even wide open throttle, hence the really bad curve.
Edited by badhairdave
Not making 288rwkw on 98 fuel, I dont think its possible to get 20psi by 3000rpm.
Increasing the ramp rate can move the response earlier too. Mine hits 20psi by 3200rpm (9 second ramp rate) but only makes 245rwkw on 98 fuel.
Graphs look like they are from a auto?
Here us another GTX3071 with poncams on a neo rb25det.
Pretty damn impressive for a 71 on only 15psi in the top range. Apparently the boost is wrong on the graph, it comes on a lot sooner than it indicates, an issue with the sensor having lag apparently.
Can read about it all here http://forum.nistune...&t=950&start=60
tuner was very surprised with the result as well.
Edited by Rolls
Cheers Lithium it felt quite good with the unfinished tune which it made 266kw and the little squirt i gave it last night it came on a bit sooner and felt really strong i shifted from 2nd to 3rd at bout 5000rpm but she was starting to break traction at 4000rpm lol. Ive never heard a 25 with a 3076 tbh but its quite whistly ill try putting a vid up of it on the dyno and ill let you be the judge :thumbsup:
Nice work - glad that went smoothly, nice stout amount of power... definitely not a normal GT3071R :D
Tbh without any prompting I'd have thought it was a GT3076R dyno plot, but dyno plot doesn't tell the whole story - after you've had some time to get acquianted it'll be interesting to see how you find it. Out of interest, with that 11blade wheel does the GTX3071R have the same kind of anti-surge whistle craziness the GT3076Rs do?
Im running a HKS EVC 6 boost controller dave i still think there is bit of fiddling with the controller to be done yet to help bring it on bit sooner
Mine's absolutely silent, are you sure its not the BOV leaking or something else?
Thanks Jeff i didnt go for more boost on the dyno but when my controller wasnt set up properly it easily shot up to near 27psi and started spinning 3rd gear at bout 90km/h :whistling:
Great work Mick!!
Did you try going any higher with boost just to see how the turbo handles it? My understanding is thats where the GTX shines.
Hey Gary cheers for the tips mate they are duely noted :thumbsup: to be honest even when the tune was incomplete it felt like it pulled all the way 7500rpm and unfortunately i havent seen lotsa revs yet.
Id actually like to thank everybody in here who gave me advice on my setup because you guys really did save me money and steered me in the right direction with my car! :worship:
Im pretty sure its all induction noise scotty well i hope it is lol! surely the 4 or 5 lads that were all over my car while it was on the rollers woulda picked up on it :rolleyes:
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
