Liz Posted November 3, 2011 Share Posted November 3, 2011 hey dave, can you post your dyno graph for the gt3071? I assume you've got the .82? Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092086 Share on other sites More sharing options...
Harey Posted November 3, 2011 Share Posted November 3, 2011 Great work Mick!! Did you try going any higher with boost just to see how the turbo handles it? My understanding is thats where the GTX shines. Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092100 Share on other sites More sharing options...
skylinecouple Posted November 3, 2011 Share Posted November 3, 2011 Fantastic result. Bit better than my 268kws. When does it feel like it's running out of puff, revs wise. Mine starts to feel flat after 5,500rpm just like the hi-flow I had from GCG. Which was a crap turbo by the way. Wasted a couple of grand on that one trying to get it over the 23okw mark. I have done 308,000k's in my car so I hope you look after yours and have as much fun as I have. Mind you, I'm on my second engine and 2nd gearbox and 2nd diff and 4th clutch, but hey, don't worry about all that. Engines are cheap so make sure you enjoy it. A couple of tips. Replace your coils around every 140,000k's. Just replacing my 2nd set again now. You will need to replace all the relays attached to the engine loom and coils at 300,000k's or before if the car is thrashed on hot days alot. Heat is the enemy. I have replaced the coil harness just now and it fixed a little miss in the top end. Have alook at engine mounts and gearbox as well, they will let go in spectacular fashion if left with any defects from constant cicuit work. So many things to do so I'll stop before I make myself stress. Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092110 Share on other sites More sharing options...
Harey Posted November 3, 2011 Share Posted November 3, 2011 *cough* I near sprayed my computer with coffee, my gt3071 sr20 curve is nearly identical, even peak power. I won't post it as i don't want to take away from micks results as that is awesome for a .63 IW on a stock manifold. No boost control issues either which is a relief. Out of interest, what boost controller do you run mick as i would have thought it would hit full boost a lot sooner (under 3k) based on my old rb25 results. Your setup is wayyy different, this is bolting on a turbo, intercooler, injectors and afm to a stock setup. Not fair to compare. Full boost under 3000rpm is ludicrous on this type of setup. Even the most responsive of turbos that hit the ceiling at 240-250rwkw cant make 20psi by 3000rpm. Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092112 Share on other sites More sharing options...
SimonR32 Posted November 3, 2011 Share Posted November 3, 2011 Interesting result, looks like it makes for a good fast car! Keen to see someone bolt one of these to a external gate set up and see how it compares with a GT3076R. Looks like it will be fairly similar Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092123 Share on other sites More sharing options...
badhairdave Posted November 3, 2011 Share Posted November 3, 2011 (edited) Your setup is wayyy different, this is bolting on a turbo, intercooler, injectors and afm to a stock setup. Not fair to compare. Full boost under 3000rpm is ludicrous on this type of setup. Even the most responsive of turbos that hit the ceiling at 240-250rwkw cant make 20psi by 3000rpm. It's doable. 2 of mine when i was trying to get it right on the rb25, unfortunately not showing 20 by 3k in either of these as we were battling boost control issues. On road it would crack 20psi by 3k in 4th on a flat road easily. Same basic setup as Mick's but with a .63 and a set of drop in cams. I heard you might be looking for a turbo, liz, I'll pm you the sr results edit: the bottom one was boost control via the right foot so not even wide open throttle, hence the really bad curve. Edited November 3, 2011 by badhairdave Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092299 Share on other sites More sharing options...
Rolls Posted November 3, 2011 Share Posted November 3, 2011 Very nice looking curve there, how did you get it on full song so early? Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092304 Share on other sites More sharing options...
Harey Posted November 3, 2011 Share Posted November 3, 2011 It's doable. 2 of mine when i was trying to get it right on the rb25, unfortunately not showing 20 by 3k in either of these as we were battling boost control issues. On road it would crack 20psi by 3k in 4th on a flat road easily. Not making 288rwkw on 98 fuel, I dont think its possible to get 20psi by 3000rpm. Increasing the ramp rate can move the response earlier too. Mine hits 20psi by 3200rpm (9 second ramp rate) but only makes 245rwkw on 98 fuel. Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092390 Share on other sites More sharing options...
SimonR32 Posted November 3, 2011 Share Posted November 3, 2011 It's doable. 2 of mine when i was trying to get it right on the rb25, unfortunately not showing 20 by 3k in either of these as we were battling boost control issues. On road it would crack 20psi by 3k in 4th on a flat road easily. Same basic setup as Mick's but with a .63 and a set of drop in cams. I heard you might be looking for a turbo, liz, I'll pm you the sr results edit: the bottom one was boost control via the right foot so not even wide open throttle, hence the really bad curve. Graphs look like they are from a auto? Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092643 Share on other sites More sharing options...
Rolls Posted November 3, 2011 Share Posted November 3, 2011 (edited) Here us another GTX3071 with poncams on a neo rb25det. Pretty damn impressive for a 71 on only 15psi in the top range. Apparently the boost is wrong on the graph, it comes on a lot sooner than it indicates, an issue with the sensor having lag apparently. Can read about it all here http://forum.nistune...&t=950&start=60 tuner was very surprised with the result as well. Edited November 3, 2011 by Rolls Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092659 Share on other sites More sharing options...
Harey Posted November 3, 2011 Share Posted November 3, 2011 Quite a lot of boost drop. Very impressive numbers though. I have seen the poncams net some pretty nice gains (Matt from Nistune's result). Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092668 Share on other sites More sharing options...
badhairdave Posted November 3, 2011 Share Posted November 3, 2011 nah, rb25 manual box. Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092672 Share on other sites More sharing options...
Mick_o Posted November 3, 2011 Author Share Posted November 3, 2011 Cheers Lithium it felt quite good with the unfinished tune which it made 266kw and the little squirt i gave it last night it came on a bit sooner and felt really strong i shifted from 2nd to 3rd at bout 5000rpm but she was starting to break traction at 4000rpm lol. Ive never heard a 25 with a 3076 tbh but its quite whistly ill try putting a vid up of it on the dyno and ill let you be the judge Nice work - glad that went smoothly, nice stout amount of power... definitely not a normal GT3071R Tbh without any prompting I'd have thought it was a GT3076R dyno plot, but dyno plot doesn't tell the whole story - after you've had some time to get acquianted it'll be interesting to see how you find it. Out of interest, with that 11blade wheel does the GTX3071R have the same kind of anti-surge whistle craziness the GT3076Rs do? Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092712 Share on other sites More sharing options...
Mick_o Posted November 3, 2011 Author Share Posted November 3, 2011 Im running a HKS EVC 6 boost controller dave i still think there is bit of fiddling with the controller to be done yet to help bring it on bit sooner *cough* I near sprayed my computer with coffee, my gt3071 sr20 curve is nearly identical, even peak power. I won't post it as i don't want to take away from micks results as that is awesome for a .63 IW on a stock manifold. No boost control issues either which is a relief. Out of interest, what boost controller do you run mick as i would have thought it would hit full boost a lot sooner (under 3k) based on my old rb25 results. Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092716 Share on other sites More sharing options...
scotty nm35 Posted November 3, 2011 Share Posted November 3, 2011 Ive never heard a 25 with a 3076 tbh but its quite whistly ill try putting a vid up of it on the dyno and ill let you be the judge Mine's absolutely silent, are you sure its not the BOV leaking or something else? Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092724 Share on other sites More sharing options...
Mick_o Posted November 3, 2011 Author Share Posted November 3, 2011 Thanks Jeff i didnt go for more boost on the dyno but when my controller wasnt set up properly it easily shot up to near 27psi and started spinning 3rd gear at bout 90km/h Great work Mick!! Did you try going any higher with boost just to see how the turbo handles it? My understanding is thats where the GTX shines. Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092728 Share on other sites More sharing options...
Mick_o Posted November 3, 2011 Author Share Posted November 3, 2011 Hey Gary cheers for the tips mate they are duely noted to be honest even when the tune was incomplete it felt like it pulled all the way 7500rpm and unfortunately i havent seen lotsa revs yet. Id actually like to thank everybody in here who gave me advice on my setup because you guys really did save me money and steered me in the right direction with my car! Fantastic result. Bit better than my 268kws. When does it feel like it's running out of puff, revs wise. Mine starts to feel flat after 5,500rpm just like the hi-flow I had from GCG. Which was a crap turbo by the way. Wasted a couple of grand on that one trying to get it over the 23okw mark. I have done 308,000k's in my car so I hope you look after yours and have as much fun as I have. Mind you, I'm on my second engine and 2nd gearbox and 2nd diff and 4th clutch, but hey, don't worry about all that. Engines are cheap so make sure you enjoy it. A couple of tips. Replace your coils around every 140,000k's. Just replacing my 2nd set again now. You will need to replace all the relays attached to the engine loom and coils at 300,000k's or before if the car is thrashed on hot days alot. Heat is the enemy. I have replaced the coil harness just now and it fixed a little miss in the top end. Have alook at engine mounts and gearbox as well, they will let go in spectacular fashion if left with any defects from constant cicuit work. So many things to do so I'll stop before I make myself stress. Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092750 Share on other sites More sharing options...
Mick_o Posted November 3, 2011 Author Share Posted November 3, 2011 Im pretty sure its all induction noise scotty well i hope it is lol! surely the 4 or 5 lads that were all over my car while it was on the rollers woulda picked up on it Mine's absolutely silent, are you sure its not the BOV leaking or something else? Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092755 Share on other sites More sharing options...
Rolls Posted November 3, 2011 Share Posted November 3, 2011 If you run a pod then they are where all the noise comes from. Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092782 Share on other sites More sharing options...
Mick_o Posted November 3, 2011 Author Share Posted November 3, 2011 http:// Link to comment https://www.sau.com.au/forums/topic/375232-garrett-gtx3071r/page/17/#findComment-6092784 Share on other sites More sharing options...
