It is an interesting result, falls over quite early for a cammed RB25 with a GT3076R though - wonder if there is a restriction somewhere or something. I would have expected a bit more, but I guess we have fairly few internally gated/stock manifold E85 results to work from.
I wonder where you've seen that.
The GTX3582 AR63 isn't a good choise. It produce exact the same power as a GTX3076r but, came on 500rpm later! A GTX3582 Ar 0.63 doesn't make sense because the turbine housing is the limited factor! And with a Ar 0,82 it is very much to laggy. I say that with experience, because i've had a gt3582 Ar0.82 on my Gts-t with a external screemer pipe :-) ther's nothing to 5k rpm and than "bangggg!!" funny but not very useful.
Is there nobody who ha experience with a gzx3076r on rb25det?
I have gtx3076 .82 on my rb25...
  • 1 month later...
The RPM is calculated though, its usually not accurate from what I have seen, how can you know every car's ratios anyway? If you can't work it out from the graph i'm sure someone will have a guess for you, without seeing the sheet I can say it would probably come on hard around 4k.
My tune today didn't pan out, speed cut and a slipping lock up clutch ruined my chances of a good result with the 71. I will be back on the weekend with the SLD back in place hoping for 350kw.
The gtx3076r is similar in spool, if not a small margin worse, than the gt. The gtx really only comes to life once you start throwing lots of psi at it. Although.. Im sure a true twin scroll housing+manifold would bring the spool back to baseline.
Any luck with the tune Scott?
I was seeing over 300kw in 4th at speed cut which I guess was around 5000 revs. Once I wire the SLD and get rid of speed cut again I will be able to see the outcome of my fine tuning. The MAC wastegate solenoid is working a treat now, it held a flat 25psi from what I could see. I will ramp it up on the weekend during the next run.
It has external gate, AVCR , 256cams, cam gear, maybe a 50/50 ethanol blend
id be happy with near 200kw at 4000rpm with 18-20psi
Why 50/50? how far away is Warwick from you? (or is there a Caltex up there?) You will see better gains from just running United e90 with none of the cold start issues we see down here...
You should come close, perhaps around 4200 revs? That's my guess.
well im doing all this on a tight arse budget and getting impatient, some parts like the HD clutch, walbro fuel pump, and now rear muffler with silencer may fail before it reaches 300kw
So i guess for now ill have to see what happens on the dyno, im thinking even 280 would be great,
50/50 blend is another cheaper option.
Edited by SliverS2
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
