It is an interesting result, falls over quite early for a cammed RB25 with a GT3076R though - wonder if there is a restriction somewhere or something. I would have expected a bit more, but I guess we have fairly few internally gated/stock manifold E85 results to work from.
I wonder where you've seen that.
The GTX3582 AR63 isn't a good choise. It produce exact the same power as a GTX3076r but, came on 500rpm later! A GTX3582 Ar 0.63 doesn't make sense because the turbine housing is the limited factor! And with a Ar 0,82 it is very much to laggy. I say that with experience, because i've had a gt3582 Ar0.82 on my Gts-t with a external screemer pipe :-) ther's nothing to 5k rpm and than "bangggg!!" funny but not very useful.
Is there nobody who ha experience with a gzx3076r on rb25det?
I have gtx3076 .82 on my rb25...
  • 1 month later...
The RPM is calculated though, its usually not accurate from what I have seen, how can you know every car's ratios anyway? If you can't work it out from the graph i'm sure someone will have a guess for you, without seeing the sheet I can say it would probably come on hard around 4k.
My tune today didn't pan out, speed cut and a slipping lock up clutch ruined my chances of a good result with the 71. I will be back on the weekend with the SLD back in place hoping for 350kw.
The gtx3076r is similar in spool, if not a small margin worse, than the gt. The gtx really only comes to life once you start throwing lots of psi at it. Although.. Im sure a true twin scroll housing+manifold would bring the spool back to baseline.
Any luck with the tune Scott?
I was seeing over 300kw in 4th at speed cut which I guess was around 5000 revs. Once I wire the SLD and get rid of speed cut again I will be able to see the outcome of my fine tuning. The MAC wastegate solenoid is working a treat now, it held a flat 25psi from what I could see. I will ramp it up on the weekend during the next run.
It has external gate, AVCR , 256cams, cam gear, maybe a 50/50 ethanol blend
id be happy with near 200kw at 4000rpm with 18-20psi
Why 50/50? how far away is Warwick from you? (or is there a Caltex up there?) You will see better gains from just running United e90 with none of the cold start issues we see down here...
You should come close, perhaps around 4200 revs? That's my guess.
well im doing all this on a tight arse budget and getting impatient, some parts like the HD clutch, walbro fuel pump, and now rear muffler with silencer may fail before it reaches 300kw
So i guess for now ill have to see what happens on the dyno, im thinking even 280 would be great,
50/50 blend is another cheaper option.
Edited by SliverS2
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
