  • Replies 128
Posted Images
So car back from suspension Place after not feeling happy with it after deca.
it went in with.
Camber Left -1.46
Right -1.02
toe Left -3.6mm
Right +2.1mm
(Yes I got my - and + correct.)
No wonder it felt like crap.
So all sorted now and ready for the weekend!
So my wife and kids get back on Sat morning after a month away, I have the same bucks party as Brisby (and Chris for that matter) and my car is also currently in 11ty bits.
So I guess I'm out. :(
Will be back and in top condition for the next one though.
Worse case will be Nats but hoping to get to Sandown Maserati beforehand.
Had hoped for PIARC on Oct 2nd but not sure that's possible yet either since I don't even have an engine in my car currently! LOL
What's happening with it?
not 100% sure what to put for 'event history'? does it relate specifically to Sandown? or just events in general? DECA's, etc? only other thing i've done at Sandown are the Driver Dynamic track days and that was a while ago.
Yeah just put anything you have done in general. Doesn't really matter.
If your entering Driver training doesn't matter.
if you are doing a full entry they want to know you have tracked/had training prior so you won't be silly.
SO driver dynamics is def the sort of thing they will like to see.
Entries closed. only 65 entrants = more track time :)
It's going to be nice an chilly on Saturday, with a slight chance of a shower.
http://www.weatherzone.com.au/vic/melbourne/sandown-park/detailed-forecast
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
