  • Replies 44
No way could you put that much power to the ground that quickly, in a vehicle of that size to allow a 0-100 time in under 1 second.
I call bullshit. But would absolutely LOVE to be proved wrong.
if they do make this car it won't be a supercar in the same way that the veyron, zonda, etc is. it will be more like the ferrari FXX (not road registerable). they'd have a hell of a time trying to get something like that to pass emissions testing.
Even so the physics involved for what they want to achieve would require it to pretty much be a drag car.
What do drag cars do 0-100?
They do 0-100mph in around 0.7 seconds.
They are 30ft long and by the time the back wheels get to where the front wheels started from they are doing 100kph.
It's kinda like trying to comprehend the size of the universe. My poor brain can't compute the awesomeness.
Edited by Cowboy1600
Not ever going to happen.
Fastest production (barely production) car i know of is the weineck cobra. 0-100 in about 2.9 sec, 0-200 in about 5 sec, 0-300 in about 10 sec.
WARNING! Video is LOUD so turn down volume first.
I do kinda want one :devil:
http://www.youtube.com/watch?v=nHSt79qjHAw
Edited by T-Rex
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
