So the concept of CVTs is pretty cool, constantly varying gearbox giving the perfect ratio at all times, also means the engine can be designed to operate in a very small rpm range for optimum performance/efficiency. The current CVTs fall over due to low torque limits and losing energy via heat due to the bands slipping.
The concept is to make this CVT out of an electrically linked generator and motor. Eg the engine drives a generator and the generator powers a motor to drive the wheels except there is no intermediate batteries or such, the coils for the generator are linked directly to the coils for the motor.
Ignoring the issues of how one would control such device (eg final ratio to control engine rpm) generally how efficient are generators and motors, what kind of losses could we expect to see? how do they compare to those of a traditional gearbox? Also how heavy would the coils be to successfully transmit say 200kw of power?
Here is a picture if you can't visualise what I am talking about.
No doubt weight, efficiency etc would make it pointless, but is the concept sound?
Discuss.
Edited by Rolls
No doubt you would be able to make it work i think, If you get two little electric motors and connect the terminals together, then spin one of the motors the other one will spin. Same concept really so I bet you could get it to work. Also I'm wondering if the power losses due to resistance in the wires and coils would be less than the losses of a trans. and you could get hub motors for even less mechanical losses, but they are shithouse for power. Pretty crazy idea Rolls.....
This. Hundred year old idea is hundred years old.
I'm talking about using it to create a CVT and comparing it to a traditional transmission weight and efficiency wise, the reason diesel-electric trains use them is entirely different.
Edited by Rolls
I am sure such a system is in use in one or more cars somewhere but don't have time to look it up. You effectively don't need a gearbox because of the massive instant torque of an electric motor.
Rolls, seems we think similar - you've been spouting ideas I've pondered in the last decade or so and (in most cases unfortunately) then abandoned due to finding out they either exist, are impractical, or just aren't actually sound as I research and learn more.
Keep it up! Sooner or later you may find you come across something that hasn't been hit on, or even something that has been hit on, used, and forgotten about due to various reasons but turns out to be a good idea again - if nothing else, having a brain is pointless if you aren't exercising it :)
Not really. The reason is basically the same. How to run a big engine with limited rev range in an efficient manner whilst being able to operate the vehicle over a wide speed range.
Same problem.
You gain quite alot of torque using an electric drive motor (depending on the reduction etc) but this is also were your problem lies. The motors are still geared (assuming your still going to use one or more final drives) to achieve speed or torque or a mixture. So you won't be achieving the same as a CVT which is always changing ratios.
I can go touch a design that is exactally what you are describing right now (Komatsu 730E dump truck) and i can also tell you it will carry a he'll of a lot of dirt but only do 60km/h
If you knew the equipment you need to get it to work pepperly then you'd realize it's not as easy as plugging a motor into a generator and away you go (not that you were thinking that)
For example, our trucks use several contactors, IGBT's capacitors etc to make them work. Not to mention all the resistors for retarding (wouldn't be necessary on a car) as well
This also generates quite a bit of heat which is another problem with storage of components and cooling
Your idea is fair enough, I think Lexus even use a similar system on one of there cars, but I think it's a solution better left for trucks/trains. Some of the parts are expensive when they go wrong and you don't get all the same benefits of a true CVT
Edited by 89CAL
This one is fairly simple. You cannot create or destroy energy, first law of physics.
It means you need an engine making in excess of 200kw driving the generator to drive the electric motor if you want it to produce 200kw. Or you need pre charged battery cells with 200kw per hour of energy stored in them.
Then you have to consider losses in energy, remember that heat is loss in energy. So if your electric motor will produce heat, it will lose some of your said energy.
Someone else has recently thought of a new cvt model that uses reduction gears of some sort.. With a tension on them. I saw it on the ABC but wasnt sure how it worked, Maybe a slide gearset.
Anyway, like I explained to my dad (LOL here we go) cant make or create energy. He thought he could get a 12v engine to run off a car battery and spin an alternator/generator. Enabling him to keep the car battery charged and create excess power. What he ended up with was a very expensive fish pond set that needs its car battery changed every 24-48 hours.
Love the idea. I think it would work....but you'd have to ask the question of why the car companies have not done it yet? There has to be SOME reason why it won't be economical
Hehe I get bored easily and always think about shit like this, I remember when I was ~15 and thought of the radial engine, turns out someone invented it in WW2 put it in planes and it failed dismally.
Yep, the goal is that you can run the motor at peak power at all times and as the speed changes the 'ratio' changes. I am not sure how you would control the load on the motor to limit rpm, but with the electric motor half you don't need a ratio, it just creates peak torque at all times. This is how it would act like a CVT, always at peak power rpm, electric motor delivers what ever 'power' it is generating at all speeds.
magnets
f**kING MAGNETS HOW DO THEY WORK?
Edited by Rolls
Variable speed hydraulic drives do EXACTLY this. We use them at work on our pit pumps. The diesel engines are set at their most efficient or max power rpm and then we just adjust the flow according.
You don't control the load.....you just control the rpm using a governor or in this case your right foot.
Lets say peak power was at 5k and you wanted to generate this peak power so had full throttle, what would stop the motor revving to say 6k? That is what I am trying to understand.
Edited by Rolls
Alright, to talk about how the actual device would work, and what the losses could/would be....
The output motor would have to be either an AC motor with a variable frequency variable voltage drive or a DC motor with some sort of pulse width modulation and possibly variable voltage control. This would all be under the control of a computer which would change the output characteristics to suit the speed and the load.
The input generator would be either an AC unit or a DC unit, depending on what makes the most sense given the choice of the motor - or maybe some clever electrical guy can tell us that there's only one sensible combination of the two units. Regardless, the generator is the dumbest part of the whole system because all it does it turn flywheel power into electrons.
The engine would probably have to be completely under the control of the same computer that's running the output electric motor. The driver would simply input a throttle position, being the main 0-100% load signal, and the computer would then run the engine to make enough power from the generator to do what it needs to do at the output motor. I'd suggest that the engine would be best run at or near peak torque revs most of the time, unless they have an operating point that provides significantly better efficiency and still provides enough torque for cruising and lighter load accelaration. And the engine would be able to be revved up to peak power for when the driver is asking for more than the engine can give at peak torque. Sacrificing fuel efficiency but extending the performance range to replicate what petrol/diesel engine drivers are accustomed to.
So, you'd hope that the engine would be able to be run in a significantly more fuel efficient manner than a normal transmission allows, thus saving some %. But you then have a generator, some sort of inverter/PWM arrangement and an electric motor to act as a transmission. The rotating electrical devices would have efficiency over 90% - but the absolute number at any time will likely depend on speed and load. So you might give away 15% overall efficiency across those two devices. The electrical efficiency of the inverter/PWM controls in the middle are something of an unknown. You'd hope that they would be >95%, but anything's possible. So I'd think you might give away up to 20% in total across the transmission. This is possibly more than the REAL power losses across a normal gearbox. You'd hope that the ECVT would have better than 20% losses, but I can see how it might not be much better. So with the possible fuel savings by running the engine better, you might be down to <15% losses compared to existing transmissions, which might put it into the same overall ballpark as existing stuff.
Now, having gone through all that stuff, if the whole purpose of all that expensive electronics and rotating equipment is just to do a CVT, I'm sure you could get much better efficiency just using a fully hydraulic transmission. Just run the pump off the engine, some tricky control system and hydraulic motors at each wheel (or inboard of each wheel to save unsprung weight), and you'd probably be much better off.
cheers
This is another idea I had, using essentially a massive fluid torque converter as the gearbox and change the gear ratio based on how the fluid dynamics work. I get the impression these systems are very lossy and a lot of energy is lost as heat though.
WIth the motor and generator combination, could you not just use an AC -> AC motor? There are no inverters, regulators, nothing needed, you could literally just wire them directly together removing a point of inefficiency.
Edited by Rolls
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
