Hahahaaaa Scott !! Reverse psychology hey?
On a serious note though....getting the fitment right before I take pictures...will put up a teaser later today.
In other news...got my new keychain from DriftBunny Decals....bling bling !! Crap photograph but looks cool in real life...mini fan blades and all :yes:
Yeah good spotto..Upper arms are next on the list..gktech are out of stock of the v3 ones..dont really wanna get china..played with a lot of setups and stocks kinda maxed out and still looks crap on one side...bent arm possibly im thinking
Ok I need help on this one please.
I am currently running 18x9 +35 with a 35mm spacer to get the rims sitting the way I want them.
Looking at ordering / sourcing some 18x10s but not sure what offset to get.
Apparently the O disk versus the A disk affects offset as well...i want max dish so going with the O disk.
What offset should I be getting if I want the rims to match my spacer set up atm?
Ppppphhhhanks :)
Hey Jez :) how you been? Love the progress. Wide stance is wide. :cool:
Was just wondering, are you happy with the current power set up, or do you have plans of achieving a few more horsies down the track?
Cheers man..yeah all good
Well I will soon have the grip to run a more powerful setup...I already have shiny new custom rocker covers....
So
...e85....front facing plenum...bigger throttle body..bigger turbo and some fun...who knows ;)
Edited by jez NF
  • Like 1
Took a few pictures this evening.....
Have the rears sitting where I want them for now....but new rims are coming from Japland anyways.....three months wait though :/
Fronts will soon have the current rears so will have enough dish finally :)
GTR wing will be swapped back to carbon wing once I get the new wheel setup right.
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
