The rear sits just where I want it to which is great. The fronts could do with being 5 - 10mm lower. This is not much I know but I would love it to be perfect. However I might hold off till I get the new rims and then get all the fiddley bits sorted once and for all.
In the meantime....picked up this bad boy - or one like this actually...no pic yet :)
post-18475-12685589506895_thumb_zps6056f
Cheers Matt....yeah once i get the new rims on and go a tad lower I will be happy with the exterior.
Update....
Putting in the monkey bar first thing tmrw morning.
Getting new coilovers in three weeks.
New camber arms are on and looks much better now.
Monkey bar installed....not without a fair bit of monkeying around though - the bloody thing was a pain in the ass to bolt in with the carpet which I had to cut in places :(
I did however put in new carpet inserts which I will get my little sister to stitch to the existing bits.
Looks awesome though and I am well on my way to having my own personal go kart
Annnnnddddd.....got my other bootlid back all painted and shiny.
Will mount the carbon wing on to it and we are back in business.
The bling bling "S" in the middle of my bonnet has been bugging me for a very long time.
So I decided to do something about it this morning. Going to paint it black with a clear overcoat. If this does not work I will just remove it altogether.
First step was to mask up the surrounding areas.......Thought about it but did not bother about the gaps in the middle as I am fortunate enough to be painting black on black which will go unnoticed.
Second step was to get out my dremel and sand paper and lightly agitate the surface so that it would hold the primer and paint........
No pics..
Third step was to give it two coats of primer
No pics..
Currently drying....
I am such a messy painter....not to mention entirely wasteful !! :closedeyes:
ETA/specs on rims?
Mid July sometime hopefully. At least I have the tyres ready to go so that will not take long. Got 18x10 +5 (max on a 10 inch rim that Work make with O Disk)
In other news.......ended up de-badging as the black looked pretty mediocre to be honest. Took me the better part of two hours to get the badge off with a hairdryer, thread and a precision hobby knife set...and then some good ol' prepsol and heavy buffing and it now looks sweet :)
This was when it first came off and left sticky marks.
This was after prep sol and heavy buffing
Used a layer of colour cure plus rubbish that I had lying around in the shed too.....must say for a cheapish brand it worked wonders....quite impressed
Also....my mirrors have suddenly stopped adjusting.....so went to check the fuse and realized I had about as much chance as scoring with Ellie Goulding as I had of deciphering the language. So I proceeded to print this bad boy out..........
Which was too big....so reduced it and laminated it
and gave the trim a freshen up wittttttttthhhhh......you guessed it.....black acrylic from supercrap
i can slightly see where its been. dont have OCD do yah? haha
NO YOU CANT MATT !! Stop being a dingbat !!
and OCD and me.....rubbish....lol :)
Can confirm this guy has serious OCD issues...
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
