Looks sick! Now please lower it... just a cm lower will make a world of difference, especially to the front..
Beginning to accept the truth in that statement.......maybe I should surprise myself with some new Teins as an xmas present.
....because parking close to the kerb is overrated ;)
  • Like 1
Update :)
Have always felt guilty for not having a GTR passenger seat and when I saw a great deal on bookface earlier this evening I could not resist picking up these bad boys......
Thank you to Jack :)
Edited by jez NF
This is what the inside of the wheel adjuster thingie looks like btw for anyone struggling to remove it so that you can take the plastic trim off...on the previous seat it took me over half an hour to get a flat head screwdriver in there to wedge open the circlip !! Anyways...the plastic bits are going to be painted first thing tomorrow.
After a bit of internet research over the last few days, I decided to just YOLO (you only live once - I did not know what it meant either initially..hahaa) and this happened...........
P.S. If I end up with a black back and bum don't try this at home !!
Everyone knows what stock seats with factory material that looked good 18 odd years ago looks like nowadays.
So there is going to be no picture for that.....
(insert picture of faded GTR seat)
This is after the first light coat...
This is after I turned up the heat and went with another two coats....
Getting my black on....
It is bound to dry patchy for the first few coats...so I am not too worried...but hopefully after a few thousand coats it will be nice and even !!
P.S. It is drying up quite nicely actually as I type this and has begun to look pretty good YAY !!
NOW TO SEE IF IT RUNS WITH SWEAT !!
Also (since I forgot earlier) shout out to Joel for being an absolute gem of a mate and remembering that I wanted tinted indicators and selling me his. Beats my DIY tinted ones any day. Though in all fairness to myself I was trying to tint amber lens..haha. Pictures tomorrow !!
Picked up a spare set of these to have a little play with replacing the amber with a clear lens....will see how we go. Thanks to...umm...what was his name now...oh yes Anthony !! :)
Tinted indicators fitted
2c6448ab-2524-4a65-b5aa-db7a3b0d5e39_zps
The seat is looking real nice.....will do two more coats to seal in the colour and ensure it has a nice smooth finish
Really impressed with how easy it is to do and it turned out not as patchy as I thought it was going to be.....HOWEVER the decisive bit is going to be if the colour runs....which we shall soon find out
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
