On 22/6/2025 at 9:45 PM, Milkmun said:
The stealth of it is sick. Custom tow bar I assume?
Yes customized and built from scratch pretty much after finally finding a local towbar supply and install place that was willing to do something "different".
Very happy with it for sure ๐Ÿ‘Œ
  • Like 1
Do you mind if I ask how much this cost to get setup?ย
Currently I put a rear rack on my bike, load up a duffle bag and ride to the track. The ride home can get a bit sketchy with how exhausted I am, if this isn't crazy expensive it would be a much better option for sure.ย
  • Like 2
It cost me $2900 all up for a local trailer / towbar place to supply and install. I did think it was a bit steep initially but after all the work involved and seeing the final result I think its well justified.ย
Hardest part was finding someone willing to customize and fit it up with trial and error basically.
Whereabouts are you located? - I had my work done locally in Wangara.
It sounds "expensive" when compared to a mass produced tow bar that gets imported from China, but if that's all custom fabrication, then I think where you've ended up, it's a pretty good price! Considering some people will pay thousands of dollars for a few intercooler pipes to be welded up!
  • Like 1
Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.ย
I'm a long way from you mate, I'm a couple of hours out of Brizzy.ย
  • Like 2
  • 3 weeks later...
Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
att.HD-mjlbhCOHOTxHzOJxx3GbigiUtMbN5pJOJrz6cJeQ.thumb.jpeg.f4bf325a1f31a714be6b9b3d177b6efd.jpeg
ย
  • Like 2
10 minutes ago, GTSBoy said:
Given the absence of lower parts, I'd suggest that they are just draped over the backrest for aesthetics in the photo.
I'm guessing its a 4 point harness, 3 of the 4 belts are visible. I'm guessing the hidden belt is tucked down between the seat and door.ย
  • Like 1
Lower parts are there. On passenger seat, bright yellow bit is the release mount. On drivers, bright yellow bit is the lower buckle for the other side.
My bet is lowers are tucked out of the way as much as possible for visuals.
  • Like 1
  • 3 weeks later...
ร—
ร—
