On 22/6/2025 at 9:45 PM, Milkmun said:
The stealth of it is sick. Custom tow bar I assume?
Yes customized and built from scratch pretty much after finally finding a local towbar supply and install place that was willing to do something "different".
Very happy with it for sure 👌
  • Like 1
Do you mind if I ask how much this cost to get setup?
Currently I put a rear rack on my bike, load up a duffle bag and ride to the track. The ride home can get a bit sketchy with how exhausted I am, if this isn't crazy expensive it would be a much better option for sure.
  • Like 2
It cost me $2900 all up for a local trailer / towbar place to supply and install. I did think it was a bit steep initially but after all the work involved and seeing the final result I think its well justified.
Hardest part was finding someone willing to customize and fit it up with trial and error basically.
Whereabouts are you located? - I had my work done locally in Wangara.
It sounds "expensive" when compared to a mass produced tow bar that gets imported from China, but if that's all custom fabrication, then I think where you've ended up, it's a pretty good price! Considering some people will pay thousands of dollars for a few intercooler pipes to be welded up!
  • Like 1
Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.
I'm a long way from you mate, I'm a couple of hours out of Brizzy.
  • Like 2
  • 3 weeks later...
Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
att.HD-mjlbhCOHOTxHzOJxx3GbigiUtMbN5pJOJrz6cJeQ.thumb.jpeg.f4bf325a1f31a714be6b9b3d177b6efd.jpeg
  • Like 2
10 minutes ago, GTSBoy said:
Given the absence of lower parts, I'd suggest that they are just draped over the backrest for aesthetics in the photo.
I'm guessing its a 4 point harness, 3 of the 4 belts are visible. I'm guessing the hidden belt is tucked down between the seat and door.
  • Like 1
Lower parts are there. On passenger seat, bright yellow bit is the release mount. On drivers, bright yellow bit is the lower buckle for the other side.
My bet is lowers are tucked out of the way as much as possible for visuals.
  • Like 1
  • 3 weeks later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
