Sau: Nsw Tech Night #2 - Suspension And Alignment
  • Replies 65
Geez... what is it with creepy old men and my sexy body?
Creepy gentlemen aside it was a good night with some solid info. I even learnt some stuff.
Thanks to team at wholesale suspension for putting the night on.
Disappointed that we didn't get Duncan's car on the hoist to play spot the oil leak. Just guessing that everyone would win a prize.
Thanks SAU NSW and the staff from Wholesale Suspension for a fun informative night.
Dear son of rajab......fml still at work, hopefully can smash this last job and get over there....steering box in a 100 series and wheel alignment:( unlikely.
May have to rock up halfa late
Even though it states that "The Legends Night" bookings are sold out Zach, you're tentaively included so long as you fix up SAU with payment real quick.
Tis great you came > good chat!
Awesome! Is that just me or me+ the wife? Just need to know as I'll process payment tonight! Much appreciated!
Agreed with all, was a good night and the Wholesale Suspension boys (and girl) were great to deal with and taught us some very useful information.
Duncan, Neil and myself had a stalker @ Penrith McD's beforehand - he parked right next to us and must have been waiting for us to come back to the cars then pounced on us with chat about his three Datto 200Bs. I guess that's what two damned fine Stageas parked side-by-side attracts in that neck of the woods, hey?
His car was pretty cool though.
lol what use is a clone unless they are under your direct control, and can do all the boring stuff you don't want to do each day.
Pat won't cut it for me, I'm going to keep working on the mechanical clone in the back of my garage.....all I need is a lightning storm to power it up muahahahahahhahahahahahaha
I kept trying to think why Pat looked so familiar! Pat = Duncan Doppleganger!
Somebody have their email? I want to thank them for such a great night.
Loads of good info:
* No "recipe" to great suspension setup
* Good suspension is about balance - to the car setup, tyre setup and duty (e.g. street, track, skidpan, strip, drift, etc)
* More <> Better - often spring rates are too stiff in straight aftermarket packages
* Balance is the key to quick - NOT flatter. Lots of guys set up for a "Flat" car not realising that weight transfer (e.g. some roll) is important to getting more grip
* It was amazing to see how 8mm-10mm of squat caused toe and camber to really move. You can really imaging then how much toe in/out changes dynamically as you go around a track.
* Interesting the effects of good aero on the suspension set-up. Those time attack cars and F1 can run less camber but still maintain even tyre contact because the aero is adding additional down force "weight" increasing grip.
Upgrades:
* Best first upgrade is a poly bush (hehe I said bush) - on 10 yr old cars stock rubber ones will just be worn out. Unless a full track car, you want a poly instead of aluminium to soak a little vibration and not transfer too much of that into the chassis from normal crappy nsw roads
* Coil overs (dampening), spring rates and tyres need to be balanced in order to work well, e.g. Stiff sidewall tyres can take stiffer springs and harder dampening, if you are just going to run road tyres then you should use looser suspension & springs otherwise your tyres are taking too much of the shock/dampening work that adversly affects their work on traction
* Sway bars are just used to control body roll to affect and maximise weight transfer (note that I didn't say body roll - it's about weight transfer/Grip relationship)
Great practical advice and enough theory explaination to help us out in finding a good balanced upgrade approach.
[email protected]
www.wholesalesuspension.com.au
02-47212112
You can confirm that their employee Matt might wish to buy 2x tix to Legends Night + any others? > Followup...
My business brain on the night asked if they'd like to make up some DL cards for SAU "Partners" to stick in their caryards and workshops? > Followup...
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
