  • 1 month later...
  • 5 months later...
Ive been such a lazy bastard with this.
Soooooo,
At the end of last year, I got rid of the old powerfc and got myself a Link G4. Man this is a nice ecu. None of that silly hickup every 10 minutes. Oh and the fact that I went ethanol :P.
After jez worked all his magic the car is pushing just shy of 340 kw on 20psi. Not bad for the baby -9's I reckon. Car is now a great street/twisty setup.
Seeing as I was starting to push the standard motor I finally pulled my finger out and bought a variety of gauges.
Oil temp/pressure
water temp
AFR
I now feel more relaxed driving around haha. I also got a asi radiator from fleebay. Bolted up perfectly :). And its all shiny. I love shiny.
Hicas lock bar, wicked, we know what it does.
Finally to top off these past couple of months I finally got some Federal 595 RSR's. whow these tyres are good wet dry they aint care. Only down side I would say right now is that they are noisy. As far as wear goes, we will have to wait and see.
All in all, car is going awesome (touch wood) except for my silly castor rods making knock knock noises, time for new ones :). Pulls hard and got a 11.4 @125mph on those crappy achilles tyres I had. Wonder if I can drop it down a peg or two with the new rubber.
Now for pics
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
