well qualifying was a bit of a anticlimax wasn't it.
the utes were better, how was that ute going off at conrod, >< that close to hitting the other ute!!!
yeah there was a coat of paint in it. hasn't that happened to lowndes the past few years as well?
  • Replies 162
i sen that near miss in the utes. that is a lot of speed to be throwing a car sideways to start with.
i wonder how long it will be before cams puts some more cotton wool on the sport and wither a) puts a chicane in to slow every one up or B ) puts a wall in to prevent cars from coming across the track infront of other cars?
wouldnt it be awsome to go and do donuts in a 32GTR on top of the mountain in front of all the drunken bogans.
in other news hopefully Lowndes/Skaife win. Skaife is an Experianced driver compared to most of the other co drivers, so that should help them on thier way.
i have very minimal interest in the V8's all year until Bathurst is on.
Edited by ML73ZR
no, lowndes has won4/5 of the last races at bathurst.
i meant lowndes having a car come sliding across the road in front of him, nearly taking him out.
ok so bacon and egg sammiches for breakfast and bbq almost ready for lunch....
i lol'd at the nascar guy.:laugh:
yeah nascar guy was hilarious
i just realised the trophy is called the Peter Brock trophy = PATHETIC its getting worse
it's been called that since he died. what should they have called it? i think you are pathetic for thinking that having a memorial trophy for the person who holds the record for number of wins is pathetic.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
