yeh thats what im kind of worrying about with the emo..
hence why i dont really want to mod it and start mucking with things..
i know i can track it the way it is and it'll be fine..
rwd is fun. i will miss that.
i searched for rwd turbo skylines in nsw for under $10G all that came up was the R33 GTS-T,
ROFL
i wonder what that means............
*edit*
my point is invalid LOL even though i put inbetween 2-3ltr the RB20 didnt come up :( LOL
for get what i said HAHA
Edited by WAGON_BOY
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
