The pro's (Ronnie/Jay in particular) don't seem to eat any tuna actually.
They eat mainly chicken, Jay has 1 red meat meal a day, and usually fish or sushi once a day (keeping in mind he eats around 10-12 meals a day)
Then before a comp he switches solely to fish...Less fat and thins the skin for a tighter look.
Ronnie is a bit more loose, eats grits with cheese instead of oats for breakfast, mixed with his egg whites, from Eggology of course.
The rest of his meals are usually chicken, baked potato, chilli cheese fries and corn bread...Good ole' corn bread.
Chilli cheese fries sounds good
Sounds unhealthy but I'm assuming its healthy. Where do I get some mang?
just bought 60cans of safcol yellowfin tuna in oil
fucken better taste good lol
Not a fan!
Go to Misty's Diner in Prahran...all American food, you can get chilli con carne fries and they are the bomb. Don't forget to put death sauce on top.
And deep fried cheese sticks...
Cheers mang,
Saved me $2,000 in flights and accomodation
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
