What's the go with that site Nick? What's postage etc like?
Thanks for the website mang, shit looks cheap
Also +1 is there a catch?
It might be okay, it's just that when I tried Safcol I was into chilli tuna...and their chilli tuna had all these pieces of onion in it, made it taste like ass. Who the f**k mixes onion with tuna outside of a tuna mornay (even then it's spring onion)?
Back in the day when I used to eat Chilli Tuna, John West was the the shit for Chilli Tuna.
The last two days were the most productive of my life, I came up with a new theory for relativity.
I regularly eat tuna (chunks in olive oil) with tomatoes and red onions...quite nice
yeah its just yellowfin in oil so i would expect it to be ok
cost $60.60 all up posted for them
postage was $11 but because its heavy
no worries
no catch, just make sure you check your postage costs before you buy because it can sometimes come more than sale prices at supermarkets
only because no one had your facebook haha
+1 Yesterday was my most unproductive day phone vibrating all day due wasteland FB.
Shit we had young Russian blondes in our office yesterday marrying old unfit men within months of arriving in Australia that provided plenty of lulz which was very distracting
Ahhh I did the Greenseas. How good was chilli tuna on the whole though? I can't stomach it anymore, just goes through me too quickly.
Nah you're wrong.
cant compare!
Shit colour to photograph the HSV with...black looks much better IMO, would be easier to compare then. And from the back will be a completely different story. Those GT look awesome from the front but HSV tail lights are still the bomb.
haha its the wog way to do it, its good
I love it, usually eat it at least once a day...
Also good with some kalamata olives thrown in after they've been soaking in a jar of olive oil...Now that I've run out of olives though, I drizzle the oil from the olive jar on the tuna instead of from the botle of olive oil...Adds some great flavor
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
