No really... or you Iraqi?
iraqi jew a little bit of weed mixed with some hard liquor some vodka that will jumpstart my heart quicker then a shock when I get shocked at the hospital by the doctor when im not cooperating when im rocking the table while he's operating...
lucky you didnt buy an r33 :ermm:
:teehee:
LOL
get off my property!
em has some sick imagery in his rhymes
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
