Screw you all, I've got mythical Japanese creature out front...
i actually have an animal thats strange looking.
these arent mine but its what they are..
people at work call them walking knobs.
so screw all of you I win
Axolotls or aka Mexican Walking Fish...
So you have them in different colours so you simply swap them out with a colour that tickle your fancy?
lol what?
i have two brown ones a black one, an albino and yellow ones..
yeh
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
