just gettin over having it sit there un used rather take the 10k~ and stick it in shares at least it feels like its doing something..
but see how i go it makes little difference im not payin interest or anything on it so see if i dont use it much this summer its goneeeeeee
Time to fix hail damaged bonnet on the 33...what do wasteland?
- carbon fiber bonnet (rest of car is silver) ~$800
- fill/prime, respray and hope for a good colour match (front bar really needs a respray too) ~$300
- buy second hand bonnet with no dents and respray (as above) ~$400
- paintless dent removal (existing paint is in good condition) ~$11ty
Money not an issue, I'll go with the CF if it looks good...I do like flush colours though. Do series 2 R33 bonnets fit a 1.5?
I vote for this.
Some cars look good with CF bonnets and some don't IMO
Birdman, S2 bonnet won't fit on S1/1.5 the headlights are different.
I'd find another bonnet in same colour as long it's in better condition than yours. Ditto for bumper - save you on paint.
10k as is sit now or I'm assuming minus all goodies?
Only issue with finding a silver bonnet and putting that on is that a good deal of my car has been resprayed a couple of times so I don't think the standard silver will match well, assuming the bonnet I find has perfectly good paint on it. I'd rather spend a few hundred on trying to match it / refreshing the paint. That and I could be waiting forever if it's a series 1 bonnet that I need. But a good suggestion nonetheless.
CF doesn't look too bad on this GTR...
Yer CF is sounding like a bad idea...I do love the look of a silver bonnet after a coat of wax. Might just respray existing bonnet and front bar, probably set me back ~$600.
MOHSEN
http://cgi.ebay.com/ebaymotors/JDM-NISSAN-SKYLINE-R34-BONNET-LIP-SPOILER-4-DOOR-RARE-/200652875902?pt=Motors_Car_Truck_Parts_Accessories&hash=item2eb7d7e87e
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
