Rofl. Signed into iTunes. Same problem. I'll try mums card when I get home.
just ask yourself. do you really need that game/app your about to purchase?
maybe you should put that 99c to charity.
I was reading the SAU facebook wall last night. And thought gee whiz, shit just got serious.
Have you read the stuff he has posted on his own facebook wall? Kris and Alvin getting called out LOL
i havnt seen the facebook wall could you link it?
i have read the stuff he has posted on his twitter and shit calling out Kris and Alvin :P
YA RLY.
Oh well, like i've put forward plainly, one does not provoke people to "come at me bro" and then when people actually do, one should withdraw his/her right to whinge and sook about security being lax. How about taking some responsibility mang.
I wanted to go all out but vice prez brah'll get youmadness
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
