come live in knox and say that :P
Mr.P is training up all his minions in rowville and knox. Two TMU stations to deal with now ~_~
i wouldnt care, you have your car for fun
if your going to be pulled over whether you car is stock or modded you can still cop the epa so just drive it with mods and enjoy it
I have a stock turbo :(
mines stock from another model
Just found out that:
- Someone is taking my grandad to court for a car accident after hitting my grandad from behind. No marks from the accident so both parties agreed to do nothing.
- Fast forward to today and now he wants money and is bring lawyers into it. And is also taking it to court
- Funny thing is letters show $3,000 of damage to the front of his car.
- Even funnier is that the 1st lawyer documents shows the other person car as a Alfa Romeo with 'x' rego then the 2nd request shows a white van with 'y' rego with $3,000 of damage.
All seems sus and wouldnt be surprised if they though becuase they smashed into an old guy they will take advantage of him. Going to do some investigating tomorrow and hopefully rip the other party a new one.
/csb bro
go ahead with the court thing then topsy turvy that mthrfkr and demand he pays for your/your grandad's day taken off from "work"
I will topsy turvy the M*therfker like no tomorrow. Will call the lawyers and magistrates to make sure the letters are legit. Then call the insurance company to let them know of the full story
Will also call the company he works for tomororw for kicks. As the 2nd invoice shows that its a company car.
Also that looks hella mexican Billy :thumbsup:
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
