oh well hes a silly bugger anyway, everybody knows you slow down before the bend on that road :ninja:
1. The speed limit drops to 80
2. Theres a retirement village
3. The cops always sit there waiting for people that dont slow down..
No tony if its over a certain amt of kms they will crush it on first offence...
Really? That's quite gay.
So if someone was having fun on a freeway in his/her Lambo, then it would essentially be a $500,000 fine.
That shit is messed up. Penalty v Crime does not weight up. You'd be better off getting thrills bashing innocent people on the street.
thats just the way it is, things will never be the same.
Yeah that's the place, was fun with 302rwkw GTR, and had couple of frights by the constabulary...
yeah the old roundabout was good you could really nail it through..the new ones alot bigger and its not that it slows you down alot but you dont have the same momentum coming out of it.
So where the old one you would slingshot out of, the new one you have to power out of, kind of killed the fun of it....
Is that the round-about with a BP and Macca's on it?
If so, nice long flat straight indeed....
Nah that's on Dandenong-Hastings rd from memory. The road Arthur and I were talking about is on Frankston-Dandenong.
nah thats western port hwy..frankston dandy rd is the next one over.. There is nothing on it but a few old farm houses an old helicopterand a cemetry..
did you know that tupac copied that song..i noly hheard the original the other day on some AM radio station
well not really because im pretty sure it was produced after he died..lol
they used a lot of old music for his chorus' after his death
yeah heading north through thompsons rd roundabout theres a nice stretch where '(dare i say it) its safe to open it up a little..but some silly buggers forget to slow down
haha i lived around there for 6 months, that was a nice little stretch
looks like some bloke was late for work on frankston dandy road this morining, now hes getting his nice new EVO..
iMPOUNDED..
Pretty funny it was too low and they couldnt get it on the tow truck..what speed would you be doing to get an on the spot impound?
i saw cops hanging around there at 8 every morning thank god i dont go that way to work anymore
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
